Old 06-19-2013, 08:51 PM   #46
Originally Posted by RC Infos View Post
Total domination of Team Magic E4RS II EVO @ the HSH Sunday Cup: http://blog.hrcdistribution.com/?p=1547
It's not a "Team Magic Cup", but the car is very popular on this region, where people like great cars
Oh My God, It is about 80% of drivers use RSII EVO on the track, what amazing!!! It seems to I made a right choice to get the EVO previously and it is a beatifully car as my favorite. Awesome cars with excellent competition
Tim M3
ferrarim5 is offline   Reply With Quote
Old 06-20-2013, 09:00 PM   #47
Wow, that are new styles of middle axle mount and motor mount with aluminum 7075 material and I think Team Magic did good job on it. The items are beautiful and fit the bearing perfectly, feel like hardness and stiffness
Tim M3
Old 06-21-2013, 07:06 AM   #48
ckracer's Avatar
Yes car is very well made!! one thing i love is quality of carbon i haven't had anything else like it!! I know 1 other company atm uses fine weave but im not sure on there quality of there 1 havent seen it 1st hand but Team magic's is so nice!!
and so many different flex setting car can be super soft or very stiff depending on how u run bulk heads and topdeck!!
<> TEAM MAGIC <> TEAM POWERS <>
ckracer is offline   Reply With Quote
Old 06-21-2013, 07:59 AM   #49
lol it's always exciting when people talk about the EVO and use pictures I do ^^
www.teammagicrc.net / www.hrcdistribution.com
RC Infos is offline   Reply With Quote
Old 06-23-2013, 06:32 AM   #50
ckracer's Avatar
Finally got to play around with some setup today and car was amazing !!
Only second time I have put car on the track and was amazed at the steering and how much corner speed.
This really is an amazing car there was a lot of people today who were very impressed....
I am so happy with this car!!!
Old 06-24-2013, 08:13 AM   #51
Hi guys,
After the tests, I can share impression,
Using a standard set up, except for the oil, I used a softer than oil in the manual.
In comparison with other drivers my E4r2evo excellent show themselves,
and won the Ukrainian regional cup.
I will continue to try make the best settings for best results!)
Viktor is offline   Reply With Quote
Old 06-24-2013, 03:45 PM   #52
Trader Rating: 20 (100%+)
Has anyone had problems with the firment of the nunchaku CVD's on the steering knuckles? I am currently assembling my kit and stumbled with this problem. On one of the knuckles, the bearing fits deeper into the plastic part permitting the axle to go thru completely thus, having complete clearance of the hole where the wheel hex fits. On the other knuckle the bearing sits flushed with the outer part of the plastic part. When I slide the axle thru it won't clear completely and the pin hole is 3/4 out from the bearing. The opening is not large enough to fit the pin thru. Does anybody had the same problem?
madness is offline   Reply With Quote
Old 06-24-2013, 04:08 PM   #53
trickd122's Avatar
Yes I fixed mine by swapping the bearings mine was the Left knuckle
Good luck
Tino
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 06-24-2013, 09:20 PM   #54
Originally Posted by Viktor View Post
Hi guys,
Wow, congratulation to guy, I can image this car kit is kind of awesome for original setting that there are good news keeping unleashed for drivers won the races.
Tim M3
Old 06-25-2013, 07:18 PM   #55
ckracer's Avatar
Default Team magic E4rsII EVO
Hi Madnes,
i was just wondering are you sure u are using the thin bearing on the inside of front knuckles some people don't realize that u can not run standard bearing when running any double joint uni!!
if so could you msg me some pics i will try help you work it out...
I'm sure it will be something little like that
Old 06-26-2013, 10:14 AM   #56
Well, I have checked the bearings and all of them are the same width. I've swapped the bearings on the knuckle that fits the axle correctly and keep getting the problem.
Old 06-26-2013, 07:49 PM   #57
hey, Guys
just wanna share a news about E4 RSII EVO just won the second place for the BaWue Cup that I just found from internet. it is cool!!
Please see the link below:
http://blog.hrcdistribution.com/?p=1558
Tim M3
Old 06-29-2013, 12:32 AM   #58
Hello
If "all of them are the same width", this is the problem !
For double-articulated "nunchaku" driveshafts, you must use the 3mm width bearings on the inside, and 4mm width on the outside. If you have 4 bearings of 4mm width, it's for sure wrong. You have to check if you used the 3mm width bearing on a wrong place (rear driveshaft or middle layshaft).
Old 06-29-2013, 05:46 AM   #59
Hey guys, looking at getting one of these TC's, what option parts are a good idea to have and what spares do you recommend, also as far as spurs go, do other brand spurs work. Cheers, I'm ordering from a local distributor and they won't be carrying spares as their is not enough market here for the car, well not at the moment hahahaha, so yeah looking at getting the basics to tie me over in the first order.
B.C.Ninja is offline   Reply With Quote
Old 06-29-2013, 06:13 AM   #60
Recommended options are:
-Aluminium battery holder
-Springs and anti-roll bars
That's all !
As spare parts, I recommend rear uprights, C-hubs, steering blocks and composite gears for diff.
SEO by vBSEO 3.5.0
