Old 08-15-2013, 04:23 AM   #181
Hi guys!
About screws
Yes, it's a screw.
I changed the screws so that we could to remove tweak.
Viktor is offline   Reply With Quote
Old 08-15-2013, 04:55 AM   #182
Trader Rating: 49 (100%+)
No matter which car you use typically a measurement that high is usually for the chassis on a level surface to the wheel axles. Are you running the specR? If so and you need setup help you may want to post there instead
No, I am running the new EVO. Just some of the setup sheets are using the specr gauge for measurements
Originally Posted by RC Infos View Post
Spec-R gauge measure distance between ground and wheel axle, when the chassis in on 10mm blocks.
Thanks. The 10mm is exactly what I needed to know.
rodneybarrett is offline   Reply With Quote
Old 08-15-2013, 10:37 AM   #183
Originally Posted by defcone View Post
Is this the screws' fault or the chassis's?
Countersunk holes just needed to be a bit more deep.
But you can also solve it with "thinner" screws heads.
www.teammagicrc.net / www.hrcdistribution.com
RC Infos is offline   Reply With Quote
Old 08-18-2013, 07:40 PM   #184
Yeap, I got this problem too, thanks for explaining
Tim M3
ferrarim5 is offline   Reply With Quote
Old 08-19-2013, 02:40 PM   #185
Robertcooper88's Avatar
Hey Guys! Got 2 new TM cars coming my way. I have a question, are the spur gears mfr specific but will most spur gears work?
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 08-19-2013, 06:59 PM   #186
most low profile spurs will work. I am using a 3rd party one on mine.
Old 08-19-2013, 07:14 PM   #187
trickd122's Avatar
Cooper
I'm running the xray ones they fit nicely
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-20-2013, 01:28 AM   #188
Yes, any 3-holes fixation spur gear will fit the E4RS II / E4RS II EVO.
Personally, I use HRC Spur Gears.
Old 08-20-2013, 06:08 PM   #189
Hi Guys,
Good news for another winning of RSII EVO again. Link below.
http://www.teammagic.com.tw/wb_main....id=79&pageno=1
Tim M3
Old 08-21-2013, 06:23 PM   #190
The car run on the track without cover, I was starting to warm up for the tires and kit with going round on the track by low speeding in 92。F degree sunny weather. Look that the charmed and spiffy body.
Tim M3
Old 08-22-2013, 07:05 AM   #191
Got my 2 Cars Late Yesterday and built one last night. What a nice build, everything went perfect!! Can't wait to get them both running.
Old 08-22-2013, 07:40 AM   #192
rc world depot's Avatar
Thumbs up
Originally Posted by patorz31 View Post
All I care about is that if i break a part i can throw on an xray part and keep racing till my new TM parts are in. If it changes the handling you adjust the car. The main point is i get to keep racing a car not supported in my country.
Team Magic Parts available at Team Magic USA distibution RCWorlddepot also G4 E4 RTR E4RSII and G4 +
rc world depot is offline   Reply With Quote
Old 08-22-2013, 12:59 PM   #193
Do you have a website?
Old 08-23-2013, 07:18 AM   #194
Default ref website
We have a website set up rcworlddepot.com it is a work in progress because we are putting together a dealer price list together
Old 08-25-2013, 06:39 PM   #195
Awesome, what version you got?? spool or Diff??
Tim M3
