Team Much More Power supply
Can someone tell me that how to change system to use with 110v from 220v model or 220v to 110v model?
In the instruction manual, they said this is factory setting.
Thanks Khun Kumpol
Does anyone know what the difference is in the normal 20 amp version to the world edition much more power supply. Any pics or links?
kumpol ygpm!
Input voltage ????
Just got my world edition power master. How can you tell if the unit is factory adjusted to 110 volt or 220 volt? Do I have to open the unit to check?
Re: Input voltage ????
The only way to double check is to remove the cover and check where the jumper is.
Who carries Team Much More in the U.S.? I like the charger and power supply.
I think you all are insain for paying nearly $200 for a power supply that only gives you 20Amp.....
I could nearly buy 4 of the Pyramid 20Amp one that is about th exact same size....
A little paint and some sticker qualifies it to cost 4 times as much....shuuuwee.
That just seems retarded...
Just my two cents
Here is my point
Here is yours
http://www.speedtechrc.com/store/ebp...nid=63&id=5085
for the same cost you get 30Amp plus it looks really nice
http://www.speedtechrc.com/store/ebp...nid=63&id=5006
Now here is mine.
http://formula1caraudio.com/product_...eba705675b0db1
There is another site that sells it for $59.95 but it doesn't seem to be working...But are you getting my point....
I hope so...
Save a little and buy some new motors and some brushes too.LOL
You bunch of label JUNKIES.....
Stephen <><
Just my two cents
Here is my point
Here is yours
Now here is mine.
I hope so...
Stephen <><
I only paid $105 + shipping for a world edition in Hongkong.
