Old 05-07-2010, 06:35 AM   #16
Default Size Matters
Originally Posted by Glowster21 View Post
Whats the advantage to running a larger spur gear? If the final drives come out the same, what would be the difference between running a 108 spur to a 37 pinion versus a 100 Spur and a 34 pinion? Do you get more torque with the larger spur or with a smaller spur?
The default is to go with the smaller diameter gear set, if only for less inertia. Smaller diameter gears will also have slightly less contact with each other, so friction will be less. The differences will be small, but they will be there. Smaller gears will also take up less space, which is an issue from time to time. As long as the ratio is the same, the output torque will be the same.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 05-07-2010, 01:44 PM   #17
simplechamp's Avatar
Trader Rating: 73 (100%+)
This is my favorite. All kinds of great RC related tools.
simplechamp is offline   Reply With Quote
Gear Ratio maximuspowell Nitro Off-Road 4 08-22-2008 04:17 PM
gear ratio? kwellst Electric Off-Road 3 10-09-2007 04:42 PM
Gear Ratio 7.6:1 Wreckless_Daz Electric On-Road 1 08-16-2007 07:15 AM
SD 2.5 gear ratio ? LeoChan Electric On-Road 10 01-29-2004 07:07 PM
gear ratio Franky Australian Racing 2 01-14-2004 11:51 PM
SEO by vBSEO 3.5.0
