F201
#1456
Location: Redford Mi. Trying to keep up with Tim Stamper
We had a great day here in Michigan for our first F1 series race at Lazer speedway , 18 cars , good clean racing , and no broken parts !
Bob
Bob
#1457
setup ideas...
i was curious about some setup... what oil are people using with the piston set. i used the single hole pistons, and wasnt sure where to start. ran last weekend, and all i got was off throttle spinout. here is the current setup:
front
4 mm height
1.5 camber
0 toe
olive spring (from d. juns setup)
type A tire
rear
4 mm height
2.0 camber
2 degree toe
black spring (also d. jun)
type A tire
front
4 mm height
1.5 camber
0 toe
type A tire
rear
4 mm height
2.0 camber
2 degree toe
type A tire
#1458
Where are you running? Carpet? asphalt? I like to use a 2 hole piston setup. Really depends on where you are running and what tires you are allowed to use..
#1459
i didnt have the 2 holes for it... just got the 1's and 3's. what we run on is called Skid-Not, kinda like asphalt. and as far as tires, i am trying to get set up for TCS, so just the A's right now, but i have some B's coming in addition to the tuned kit... right now, im just running a slightly hopped up original version.
#1460
tamiyadriver
I mostly use either 60 weight Trinity oil with the 3 hole pistons on asphalt or 80 weight Trinity oil with the 3 hole piston on carpet. If the track is really bumpy, you want less dampening and if it's smooth, you want more dampening.
#1462
tamiyadriver, If you ever get the chance to use it, try out a CF chassis. IMO its about the biggest performance changer you can do to the car.. Cant wait untill Tamiya gets with the program and releases a TCS legal one...
#1463
Man I envy you guys....
here in New Zealand the F201 isn't allowed to race in any class.
#1464
Who will make it out to the TCS regional at Tamiya HQ?
#1465
I'll be there with a decent contingent from NorCal. I'd say we'll have 10 or 12 guys coming down. How's the bike?
#1466
Square F201 parts
Just browesing this www.allspeedhobbies.com and saw that they have Square parts in stock. The tires are pretty cool, 'cause they have Michelin printed on it.
Allspeed hobbies
Allspeed hobbies
#1467
Originally posted by Tamiya Virus
Check out www.formula1-rc.com. They have some info on the nitro F1 (check either articles or news section).
My understanding is that a couple of companies are working on this. One of them is Serpent, if I'm correct.
#1468
#1469
I'm there dude! By the way, good run at Reedy
Steve Wang
#1470
Thanks Steve, I'll be calling you regarding tires for TCS.
