Problem with Team Associated B3
Hi,
Recently i have bought a Team associated B3, built it all, worked fine with my 21 turn motor, a Ripmax no limit esc, and a 3000mAh battery, now, i also have a tamiya tl01, which around easter time i bought a new 11 turn motor, the no limits speed controller and the 3000 mAh battery. Really i want to put the 11 turn into the B3, so i took out the 21 and put in the 11. Bare in mind i am also swapping over the ESC and battery as i only have 1 of each. So i turn on the reciever and turn on the ESC and it goes all wierd, steering twitches, when i move the accelerate stick upwards it jutters, then accelerates without me doing anything, i have changed everything over from my tl01, which works fine with the 11 turn and esc. I really dont understand why it wont work in my B3, because i know it would fly around the garden, which was my main reason in getting it. If anyone has any ideas it would be much appreciated if you could post here please.
Thanks,
Mark
Thanks,
Mark
