VG Damper Oil...Anyone Using?? >
Old 05-02-2011, 06:02 PM
DaveG28's Avatar
Trader Rating: 65 (100%+)
Default VG Damper Oil...Anyone Using??
Just wondered if anyone has been using the Tamiya VG damper oils and if so how have you found them?
I used them in the winter and had issues, but that was in temperatures well below 0 celcius! Wonders how they behaved in normal conditions?
DaveG28 is offline
Old 05-02-2011, 09:58 PM
Suspended
Trader Rating: 69 (100%+)
They are just rebranded Muchmore oils (without last digit 0). For reference you can check below:
eComet is offline
Old 05-02-2013, 12:12 AM
Suspended
After some research, the Tamiya VG is not the same as Muchmore oil.
Tamiya uses mineral oil while Muchmore uses silicone oil. There is no direct comparison between different brands. The best bet is try it out.
eComet is offline
