Which of these would you choose?
I need your help!
I'm about to upgrade by broken Brushed motor in my stock tt01. I use it for drifting. I've brought from RCMart before and I'm going to buy an engine combo from them. There are so many opinions on how many turns I'll need and what ESC is good. If you've got a minute. Could you look at RCMarts website and check out their Combo » Motor / ESC section and let me know which you'd buy. Primary use: racing around car parks with friends. |
Originally Posted by danielfromnz
(Post 12087754)
I need your help!
I'm about to upgrade by broken Brushed motor in my stock tt01. I use it for drifting. I've brought from RCMart before and I'm going to buy an engine combo from them. There are so many opinions on how many turns I'll need and what ESC is good. If you've got a minute. Could you look at RCMarts website and check out their Combo » Motor / ESC section and let me know which you'd buy. Primary use: racing around car parks with friends. This is a pretty good deal on a brushless ESC and a 17.5 motor. |
Originally Posted by hyujmn
(Post 12087801)
Hobbywing 10.5T combo, what most drifters use. This is about 2 times more powerful than your current brushed setup, it is $90 and is just about everything you need.
http://www.rcmart.com/cb0584-p-35726...Path=1100_1252 |
Originally Posted by RogerDaShrubber
(Post 12087832)
I have a Hobby King HKGT2R receiver. Will it run on a on a 5000mAh NiMH battery ok? |
(Post 12087855)
"Just about everything" what else might I need?
(Post 12087883)
You will need A battery connector and a solder iron to connect the wires up, this is standard on all brushless systems, yes it will run on a NiMh you will just have to use the program card to turn off the lipo cut off value. Or better yet, just upgrade to Lipo bateries and lipo charger at the same time.
I've got my new motor & ESC in the mail today. Pretty excited to get it going. Alas, after installation the motor clicks, chirps & jitters but doesn't run when i pull the trigger. It doesn't sound happy at all. Out of the car the motor spins but not very fast. I went with the 10.5t & Hobbywing ESC. The motor is sensored and the ESC is sensorless. Should it still run? I'm running a NiMh battery. Any advice? Dan |
You should've gone with what I told you to get. That 80a ESC is meant for Off-Road vehicles and running 3s+ Lipos.
(Post 12115784)
Any way to get it to work or do I need more gear? Dan |
Not really. You could always try and get a 3s lipo but that is a ton of power.
(Post 12116614)
Damn. The other guy said that the 80a combo was what most Drifters use.
Originally Posted by goots
(Post 12116924)
you're motor gearing and/or esc settings are off. I suggest you read the manual thoroughly and do your own testing on gearing
It will likely be your nicads. Charge them before testing. If they are old they just won't have the juice needed. If you need to replace it get one good lipo (hobbyking hard pack turnigy 5800) and it will be good.
The TT01 gearing is quite limited, so I doubt it's that. |
Originally Posted by Qatmix
(Post 12117853)
The TT01 gearing is quite limited, so I doubt it's that. DWS |
(Post 12115497)
Hey guys,
The motor is sensored and the ESC is sensorless. Should it still run? I'm running a NiMh battery. Any advice? Dan most sensored motors wont run on a sensorless esc |
