Old 05-20-2013, 07:00 PM   #121
locked's Avatar
Originally Posted by lifeguy View Post
Ran my torque version from Express Motorsports today at Lou's speedway TQ'd and won, carpet track, geared at 3.65 and 53 degrees of timing! Car was fast lots or low end power!
Grant
yup
I was running a Killshot "TT" too and Adam was running the stock broad power band rotor with torque stator.
All were very quick. I was at 3.8FDR with around the same can timing as you. 53ish. The acceleration with a fresh battery really surprised me. It launches out of the corners. Next time I'm going to try a bit lower FDR. With all the reports of people smoking them, I wanted to err on the conservative side.
Liking this motor so far.
Grant, next time we race, I'm going to push it a bit harder and maybe put some new 28s on, so look out buddy.
locked is offline   Reply With Quote
Old 05-21-2013, 01:10 AM   #122
B00t13g's Avatar
Grant
Any idea what you were at when using a d3.5 with a 12.5 torque rotor? Track size?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-21-2013, 06:33 AM   #123
Lou's track is 50x95 I believe, I ran the D3.5 with broad band rotor, straight out of the package, just installed bearings! I ran full timing with a 3.88 FDR two fans...
Grant
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 05-21-2013, 10:33 PM   #124
B00t13g's Avatar
Ok, what's the trick to getting this motor to fit in a t4?
I can get it to thread in, but it tweaks the crap out of the chassis. Literally indents it. This t4 has never been run, doesn't even have electronics in it yet.
Mackenzie Meyercord
Old 05-21-2013, 10:42 PM   #125
Trader Rating: 27 (100%+)
Putting in a mod motor instead!
You're too fast for stock now, Mackie.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 05-21-2013, 10:49 PM   #126
B00t13g's Avatar
That's my stock car for eos this summer. Mod car is still together
Mackenzie Meyercord
Old 05-21-2013, 11:43 PM   #127
B00t13g's Avatar
Great job trinity! The end bell is flat out drilled wrong and will not go in a t4 in any position.
Mackenzie Meyercord
Old 05-21-2013, 11:52 PM   #128
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
You cant pin all the blame on Trinity! That's xrays fault for having that mounting design. Two independent design compromises= unfortunate and unlucky f*uck up.
Racing4Evo is offline   Reply With Quote
Old 05-22-2013, 12:07 AM   #129
Not sure how but I watched 6 guys buy killshot motors this past Saturday and put them directly into their T4's. I would've put one in but they were all bought before I got to the track. Warren Weaver, a page or 2 back was one of them. Maybe PM him and ask, I'm sure he'll have no problem helping you out, he helps me when I need it with no questions asked
JOE SI is offline   Reply With Quote
Old 05-22-2013, 04:22 AM   #130
Penz316's Avatar
I got the same problem as you. What I did : put a 2mm shim in front of the motor mount. You will need a longer screw for the hex.
After that, You will not regret your motor
Alex Fournier
Team Associated | Reedy | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 05-22-2013, 04:37 AM   #131
Potoczak's Avatar
Trader Rating: 107 (100%+)
I'm having a problem adjusting the timing, no matter how loose the screws are it just won't turn. What am I doing wrong??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-22-2013, 04:56 AM   #132
Trader Rating: 54 (100%+)
Great! and I just ordered a KS motor for my T4. Does anybody have pics of KS motor in a T4. I know people are using them.
Jamison R is offline   Reply With Quote
Old 05-22-2013, 06:59 AM   #133
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
I switched to the revtech plate from the original motor if you dont have any pm me i have a bunch of them problem solved for now until somethings done about it
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 05-22-2013, 07:19 AM   #134
thisguy2849's Avatar
To address the 2 problems of the motor not fitting and not being able to adjust the timing do these 2 steps. If it wont fit switch to a revtech endbell if you have one. On some motors the manufacturer misdrilled the holes. And timing you will have to take off the timing end remove the ring and sand it a little bit so it will turn.
thisguy2849 is offline   Reply With Quote
Old 05-22-2013, 07:43 AM   #135
Autocratic's Avatar
Trader Rating: 26 (100%+)
Mackie,
I have a faceplate if you need it.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
