Old 04-25-2013, 10:13 AM   #31
How do the dyno results compare with the D3.5?
Team Serpent
Steve S is offline   Reply With Quote
Old 04-25-2013, 10:14 AM   #32
AdrianM's Avatar
Originally Posted by drsfly View Post
Ok-- so who has them I stock?
What is the preferred version for:
17.5 touring----- rpm or torque
12th stock--- rpm?
burn it up at 60'.....????????
or perfect at 45'(with more ----gear---- or 52' with a tooth less..............)
Where do you start --- when you can get one!
I like the theory---- give them everything..... but entry , testing costs could escalate rapidly!
D
Anyone that has been racing for a few months and has bothered to do a little work figuring things out could make the following educated guesses:
What is the preferred version for 17.5 touring?
We race blinky. In blinky torque and the ability to turn big gears = speed so I would get the torque version first.
burn it up at 60'????????
No. Everyone that races should know that past Revtech's and D3.5's had 30 deg timing built in. This meant that 0deg = 30deg and the 20deg that most of us ran really was 50deg. I would start my Kill Shot (torque) 17.5 at 40deg and gear it just like any other Trinity 17.5 in a sedan, somewhere around 3.3-3.8 FDR (for big open tracks to tight tracks).
Run 2 min, temp your motor, if all is well crank the timing to 45-50 deg, run 2 min, temp your motor, if all is well start altering your final drive ratio. The best final drive is highest numerical ratio that gives you the best lap times. Also, don't look at single fastest lap. Thats meaningless, everyone gets lucky once in a while. Look at your best 20 laps.
If you are going to the Nats the best place will be the track side shop. I am sure they will have a ton. After the Nats they will be everywhere
drsfly, I am not directing this at you, i'm just saying...
No one ever said r/c racing was a cheap hobby. I don't mean to be rude but if people can't swing buying motors and testing maybe they should be focusing on more critical things in their lives.
Adrian Martinez
Old 04-25-2013, 10:17 AM   #33
Team EAM
EAMotorsports's Avatar
Trader Rating: 76 (100%+)
Send a message via AIM to EAMotorsports
I havent had a chance to run any yet but on the dyno they look very good.
The stators are different on the Torque and RPM versions but its not the length. Both stators are the same length. Resistance on the gwinstek meter was low 22's to high 21's.
On the dyno at 55 degrees of timing (According to the endbell) the RPM version pulls a little more amp draw (.2-.5amp), has a little more rpm (500), and is about 2 watts higher on each step than the torque version. The Torque version doesnt have as big of a spread top RPM to full load (as it shouldnt because it has more torque).
The RPM version looks like a D3.5 with standard rotor on the dyno and the Torque version looks like a d3.5 with a 12.5 HT rotor on the dyno....with lower amp draw.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 04-25-2013, 12:37 PM   #34
Originally Posted by AdrianM View Post
I would start my Kill Shot (torque) 17.5 at 40deg and gear it just like any other Trinity 17.5 in a sedan, somewhere around 5.3-5.8 FDR (for big open tracks to tight tracks).
Wait... what?
-Mike
Old 04-25-2013, 01:24 PM   #35
bkspeedo's Avatar
EA
With that kind of mechanical timing added, the 0 mark must be true zero?
Can you say what the real difference is between the Rpm and Torque Stators? Inner diameter different?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-25-2013, 01:29 PM   #36
Team EAM
Yes zero is zero.
Dont know what the difference is.
EA
Contact Us
Old 04-25-2013, 01:42 PM   #37
AdrianM's Avatar
Originally Posted by grippgoat View Post
Wait... what?
-Mike
I fixed it...sorry...flipped some numbers.
Adrian Martinez
Old 04-26-2013, 07:36 PM   #38
Robertcooper88's Avatar
Has anyone else had problem getting the kill shot motor screws in on a T-4?
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 04-26-2013, 08:41 PM   #39
And the sensor board doesn't move! Took the motor apart, the galvanized ring that holds the sensor board does not turn because it is too tight to the end bell, you have to pull the ring out, turn it and put it in the correct place you want the timing in. Looks like they pushed this motor through design, engineering and production! BRUTAL! Also, a ton of spacers on the rotor to get the play right. Ridiculous! Let me know if you want to buy this thing! I'm done!
Old 04-27-2013, 09:10 AM   #40
^ Really? Having to sand the little ring and shimming a rotor is enough for you to throw in the towel? Wow...
JamesL_71 is offline   Reply With Quote
Old 04-27-2013, 10:13 AM   #41
No dude! Not going into the car is deal breaker for me. It doesn't go into the associated 6.1 either. The end bell on the pinion side is drilled wrong. However, if you change the original rev tech end bell it fits! What does that tell you? IT WAS DRILLED WRONG and does not fit the T-4 or the associated.
Old 04-27-2013, 10:38 AM   #42
Trader Rating: 38 (100%+)
Now that Trinity has a new motor out, can we send in our D3.5 and exchange it for this? Not that I want to run a KillShot or anything else that Trinity makes for that matter, but it would certainly have a better resale value.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 04-27-2013, 11:51 AM   #43
Sounds like the lightweight Revtech end plate or the D3.5 end plate. Just take the screws out, rotate the end plate 1/3 of a turn, and put the screws back. Repeat as needed. Looking at the pics of the end plate, it just needs to be rotated to line up with the motor mount screw holes. It looks like you need the side that has a motor can screw and the double mounting screw holes rotated to the bottom.
Serzoni is offline   Reply With Quote
Old 04-27-2013, 12:34 PM   #44
Trader Rating: 49 (100%+)
Exactly....
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 04-27-2013, 01:07 PM   #45
Team EAM
Mine fit in my T4's fine when I did a trial fit last night. The shims on the rotor are all already on there so no issue with that. Every motor has shims. It appears that they just wanted to keep using the same rotor since so many have them already and didnt want to use a new style one. The timing ring is messed up. This batch they got to tight and they are hard to turn. I lightly sanded the steel back plate on all the ones I got in and they turn fine now. It will be corrected on the next batch that comes in.
I'll be sporting mine at the Asphalt nats in 5 days!
EA
Contact Us
