Old 04-26-2014, 01:12 PM   #376
Originally Posted by Jerz616 View Post
you would just the High torque version. it comes stock with the purple broadband rotor. If you want the HT/HT that people are talking about then you would need to get the 12.5mm turquoise HT rotor. Or you can order them together as the maxilla. Most people are using a motor checker like one you can get from team powers. Some people actually have dynos like we use on full size car, but these are used mostly in pan car racing. Heres a pic of the motor checker and a link to the dyno.http://www.mcpappyracing.com/dyno.php
thanks any one have one of these and what electronics do they use to get those plots? I may have to check out how to run a brushless motor on my old Fantom Dyno. I was looking at the Kill Shot descriptions and it sounded like the Maxilla came with the RPM stator and the 12.5mm turquoise HT rotor???? Are there different versions of the Maxilla?
John Wallace2 is offline   Reply With Quote
Old 04-26-2014, 03:03 PM   #377
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
You can get the Maxzilla in both the RPM and Torque Stators.
CR Performance Custom RC Parts (PM for details)
Colin Roussel
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 04-26-2014, 03:13 PM   #378
CL
CL's Avatar
Trader Rating: 32 (100%+)
Yes.
Believe in yourself!
CL is offline   Reply With Quote
Old 04-27-2014, 10:44 PM   #379
hanzo3's Avatar
Trader Rating: 55 (100%+)
I have a beast kill shot. Double torque. I am getting temps at 130, at 62 degrees timing. This is a small carpet track. Can I increase timing, or gear up?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 04-28-2014, 08:18 AM   #380
Jerz616's Avatar
Trader Rating: 49 (100%+)
62* is pushing it on timing. your prob getting to the point where its becoming less efficient. if its a small track you don't need all that timing...I would go 55* max and just gear for temps. If its small then you prob need more low end then more top end speed.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 04-28-2014, 10:24 AM   #381
d16dcoe45's Avatar
I was running about 60 deg on a small carpet track geared 4.05 fdr on a rpm stator/aqua torque rotor. Temped around 145. I wouldn't go past 60, so in your case try adding some gear.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 04-28-2014, 01:33 PM   #382
Hey Chris,
I had the same motor for gt 10 yesterday and it worked really well. Check your pm.
farmbridge2404 is offline   Reply With Quote
Old 04-28-2014, 11:39 PM   #383
Ran my RPM 21.5 KILL SHOT the first time this weekend and was impressed. Really narrowed the top end gap between me and the fast guys in USGT. In the second A main I think I was just getting into its power band but I had a broken suspension part and was just cruising to get points for our series, but still had some of my fastest laps all day. Motor was 60* timing FDR less than 3.6 (very big outdoor track) and temp was less than 140F with a fan on a 90+ degree day (Yea Texas). Still room for more gear and the next race is at a bigger track here in San Antonio.
However, while adjusting the timing, I lost one of the end bell screws that holds the timing ring. (Thing ran two quals and two mains with only one screw holding the timing ring in place). Anyone know what size of a screw the Kill Shot motor uses? I know its different than what's on a Tekin Gen 2 motor.
Old 04-29-2014, 05:18 AM   #384
cruzzing's Avatar
HI all killshot MOTOR drivers running 13.5 small indoor track just popped my 5th motor .
must say the killshot are quick but very inconstant. some have popped at 45deg some at 35deg some at 70deg.
Timming all around the 50 to 60 deg mark .
running the ht-ht hr-ht also standard rotor .
Must say that it still cannot keepup with the now BAND D 3.5 MOTOR .
cruzzing is offline   Reply With Quote
Old 04-29-2014, 05:19 AM   #385
cruzzing's Avatar
Old 04-29-2014, 06:28 AM   #386
Chaz955i's Avatar
I have been running my 17.5 Killshot since it came out. Torque rotor and RPM stator. No issues and not giving up much to the D3.5s I compete against locally. Running 50 degrees on the can and 3.95 gearing on the touring car. Normally comes off around 145-152 so I'm fairly conservative on how hard I'm running it. That said I know of a few people who have smoked these motors running similar setups so I doubt I'd buy another. Too much of a gamble when there are other options that are fast and don't seem to be as inconsistant in quality. Really liking the new Team Scream motor in my 1/12th scale.
Chaz955i is offline   Reply With Quote
Old 04-29-2014, 07:26 AM   #387
There a 5x2.5mm flathead, you can use cap head ones no problem as well
Colin Roussel
Old 04-30-2014, 01:00 AM   #388
EDWARD2003's Avatar
A tad confused on what rotors I'm allowed to use in a "standard" 21.5 D3.5 motor. I've seen some posts on high torque and rpm stators. The "standard" 21.5 D3.5 will have what kind of stator? high torque or rpm?
Is it possible to use a 12.5 turquoise rotor in my "standard" 21.5 D3.5? I'm looking to change out the purple rotor for more torque in my 1/12. I'm running on a tight technical track and need the get up and go like the ORCA 21.5 TX has. Should I look into going for the pink rotor?
What are your thoughts?
EDWARD2003 is offline   Reply With Quote
Old 04-30-2014, 03:21 AM   #389
Old 05-03-2014, 12:06 AM   #390
Yes it will fit your D3.5 (as well as D3 and Revtech motors). Don't know what stator comes with the 21.5 D3.5.
SEO by vBSEO 3.5.0
