Old 12-31-2013, 03:17 PM   #316
Madulla's Avatar
I switched back to Trinity after I had 2 Reedys 17.5 smoke for no reason. Taking out 2 ESCs and a battery.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 12-31-2013, 04:40 PM   #317
edhchoe's Avatar
Trader Rating: 41 (100%+)
I just ordered a Mach 2 17.5. I will post here when it goes poof. I will gear it at 4.1 to start with.
edhchoe is offline   Reply With Quote
Old 12-31-2013, 06:20 PM   #318
edhchoe's Avatar
Here is the video of my killshot letting out the magic smoke.
The car comes to a stop around 2:10 and the corner worker runs for it.
+ YouTube Video
Old 12-31-2013, 06:40 PM   #319
bkspeedo's Avatar
The mach 2 is very fast at 30-32deg timing and 3,8 - 3,7. If your more of a beginner to intermediate driver stick with the 4.0-4.1. Make sure you use a fan.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-31-2013, 08:26 PM   #320
Trader Rating: 20 (100%+)
Is it me or just everyone that runs a killshot rpm that poofed their motors overgeared?
goots is offline   Reply With Quote
Old 12-31-2013, 08:32 PM   #321
edhchoe's Avatar
Thanks for the tip!
It ran fine the first three days and I went down a tooth on its final day.
The insulator melted on one side.
Old 01-18-2014, 01:11 PM   #322
Cadman1981's Avatar
Can you guys guide me to the proper motor plate i need for my Killshot motor.
I have a Yokomo BD7 2014, and the stock endbell doesn't fit the motor mount properly
This is my motor plate
This is the one i need
Does this one fit?
http://www.amainhobbies.com/product_...eramic-Bearing
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 01-18-2014, 04:41 PM   #323
sashimi999's Avatar
I have switched back to d3.5 after 2 killshot burnt.
I am regret to say the d3.5 is still un-beatable and can survive under higher temp even it is 20g heavier ...
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 01-18-2014, 04:45 PM   #324
sashimi999's Avatar
I can give u my front plate from my "well-cooked" 13.5t.
Does this one fit?
::Michael C::
Old 01-18-2014, 07:49 PM   #325
I guess the killshot needs alot more cooling than other motors......
bertrandsv87 is offline   Reply With Quote
Old 01-18-2014, 08:17 PM   #326
Having an odd issue with my new KillShot 21.5 motor. It's in a F1 car with an orion r10 pro esc.
Basically if I pull on full throttle from a stand still it takes about 1 second to rev up. Almost like for that first second it acts like it is on 10% throttle. Thinking it is a sensor board. Have a new 17.5 KillShot that is due to go into my TC so I may do a sensor board swap to test.
J-PaP is offline   Reply With Quote
Old 01-18-2014, 09:45 PM   #327
Tommy R's Avatar
Not so sure about that. Certainly wasn't the problem in my case. My motor was coming off at no higher than maybe 130*F or so the night it decided to blow up and take out my ESC in the process. Never again.
Tommy R is offline   Reply With Quote
Old 02-18-2014, 09:59 PM   #328
snuvet75's Avatar
Trader Rating: 14 (94%+)
Now that I've read every single post here, I'm worried that the same poof will happen to my killshots LOL. When I started checking this thread, I was just wanting to find out WHAT THE THINNER SHAFT DOES(modified) and WHAT THICKER ROTOR DOES. Apparently both either give high torque or high speed, correct?
Anyway, so far my motors are fine after about 2 hours of running each.
17.5: HT/HT FDR:3.49 MOTOR TEMP: 145 Timing: 55 Track: indoor small&tight carpet Temp: 60ish nowdays
21.5: RPM/BP FDR: 3.0 MOTOR TEMP: 100 TIMING: 40(STOCK) TRACK: outdoor large asphalt with long straight TRACK TEMP: 100-130F
Another guy at the asphalt track burnt his 17.5 though. Not sure of his gear ratio. He wasn't sure of that either when I asked LOL. Anyway, did anybody find any magic solution to that yet??
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 02-18-2014, 10:07 PM   #329
Tommy R's Avatar
The failures aren't related to overgearing or overtemping or any other kind of mistreatment. Mine was running only 125*F (at most) with a mild gear. All other stories I've heard of Killshot failures have been in similar situations. Personally, I wouldn't even consider running a Killshot again. My ESCs are too valuable to me and I won't risk melting another one.
Old 02-18-2014, 10:15 PM   #330
snuvet75's Avatar
Yeah I read your posts Tommy. Well both my motors are virtually brand new LOL. I guess I'll just have to be monitoring real close.
So what are you running nowdays Tommy?
