Old 12-29-2013, 06:27 PM   #301
JimmyMac's Avatar
Haha beat me to it!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-30-2013, 07:36 AM   #302
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by edhchoe View Post
My killshot 17.5t went up in smoke last night as well in Seattle.
I have had it for less than a month and used it for three previous race days (9 heats).
Yesterday, it ran fine for two qualifying heats and during the main it came to a stop and smoke came out of the car. I thought it was the speedo but it was the motor.
Car is VBC d06.
FDR: 3.7
Timing: 57
ESC: Novak edge
This problem doesn't seem to be unique to the Kill Shot motor. Ever since the introduction of the Revtech motor line, random failures have been reported by many racers despite the motor operating under normal parameters. I'm convinced that the problem is related to the insulation used on the stator windings, or the process used to wind the stators...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-31-2013, 04:37 AM   #303
MrRolla's Avatar
Trader Rating: 29 (100%+)
Kilkshots are complete and utter garbage. I had 2 fail on me for no apparent reason. One took my orca esc with it. I will never touch another one. Never had a motor failure in 2 years and to have 2 of them blow within a week is just BS.. many others having them blow in the same fashion as mine aswell.
Trinity get your act together and admit you got it wrong.
MrRolla is offline   Reply With Quote
Old 12-31-2013, 07:54 AM   #304
RacinJ's Avatar
Are most of the Kill Shot failures occurring in TC's or are 1/12th scale and WGT experiencing the same failures?
Are the RPM or Torque stators failing more often?
Where in the stator stacks are the winds failing?
With the low voltages we use in r/c, it seems odd that these motors are failing so often.
Roche P12 '16 & '17; Team Scream 17.5 & 13.5
1/12th scale, just 1/12th scale.
I love to go like hell for 8 minutes.
RacinJ is offline   Reply With Quote
Old 12-31-2013, 07:54 AM   #305
RacinJ's Avatar
Old 12-31-2013, 08:45 AM   #306
bkspeedo's Avatar
I agree 100%. There's some flaw in the stack design or manufacturing of the Revtech\Killshot motors that causes them to short very earlier in there life. I had 2 Revtech's burn up within the 1st month after i bought them. What's surprising is how Trinity has not fixed the issue as the Killshot has the same problem.
Reedy had a similar issue with the Mach 2 but fixed immediately.
Trinity probably makes the fastest motors out there but the quality is just not there.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 12-31-2013, 11:03 AM   #307
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Can't comment on 1/12 but I have seen higher failure rates with the Killshot versus other motors in the 1/10 TC class here. I've been a bit lucky and haven't had any of my Killshots go poof on me yet (two 17.5's and a 21.5) but they are pretty quick.
I've seen some go even when they were running cool and/or on a cold day as well. Definitely not overheating as a cause for those ones.
Dan is offline   Reply With Quote
Old 12-31-2013, 11:49 AM   #308
edhchoe's Avatar
Trader Rating: 41 (100%+)
Mine was running cool. I was shocked and disappointed when it happened. I was on pace to finish 2nd in b main.
edhchoe is offline   Reply With Quote
Old 12-31-2013, 12:48 PM   #309
Ryan14's Avatar
What is the timing set to on all the motors going "poof"? Anyone care to chime in? I've never ran more than 50' on any motor i've owned and never had a problem
Its only fast if you know how to drive it.
TeamAHK | Horizon Hobby | Umbrella Hobby | Action Hobbies Kingsville | Edward Jones Investment | CIBC | Hobbywing | Cerberus | SkyRC |
Ryan14 is offline   Reply With Quote
Old 12-31-2013, 02:24 PM   #310
bkspeedo's Avatar
It really doesn't matter what the timing or gearing is, being reasonable. If the motors going to develop a short it will do it at any setting.
Brent Klingforth
5280 Raceway
Old 12-31-2013, 02:31 PM   #311
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Ryan it isn't a matter of heat over gear too high of timing these motors are shorting out. it usually happens in the first two or three race days after that they are bullet proof. I have one I have run since they came out every weekend, I had one that went poof on the second race day and the track temps had cool from the start of the day, and It was only 5 laps into the heat race.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 12-31-2013, 02:36 PM   #312
oeoeo327's Avatar
I've seen BRAND NEW Revtechs and Kill Shots go "poof" after 3 laps. It only took me 5 laps to kill my last Revtech. All of the "extreme" examples of failure were installed properly, timed properly, and geared appropriately for the layout. Gearing and timing aren't to blame in these cases - these are failures caused by manufacturing-related defects.
Old 12-31-2013, 02:38 PM   #313
Andrew Knapp's Avatar
Send a message via AIM to Andrew Knapp Send a message via Yahoo to Andrew Knapp
I usually run between 55-60 timing in my killshot, and my motor comes off at 140 degrees at the hottest for 12th scale. I would try to stay under 160 degrees that way you cannot over heat it!
Team CRC www.teamcrc.com--Team Trinity--Revtech--Team Spektrum www.spektrumrc.com--protoform--SXT--Rapid Competition RC Raceway and my dad!
Andrew Knapp is offline   Reply With Quote
Old 12-31-2013, 02:44 PM   #314
edhchoe's Avatar
57 timing and below 130F x about 60 min total run time on the motor in less than a month. => poof!!
Old 12-31-2013, 03:07 PM   #315
Trader Rating: 20 (100%+)
I had the same problem with a brand new rpm 17.5. ran fine and cool in practice, then in the 2nd qual car stopped and smoked. I looked and the windings in one area were melted. I was running it in a awesomatix with orca ESC at 3.7 with 58* timing.
I have another one that i have run many packs through from Express and its running strong.
Donny Banks is offline   Reply With Quote
