Old 11-30-2013, 12:04 PM   #286
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by rc car guy View Post
so how does this motor in 17.5 racing compare to another 17.5 say the d3.5? or another motor
There isn't much that compares to the D3.5. But that's why it's going to be done with as of March next year. If your club allows them then that's prob the motor to run. I have a Killshot and an Orca and like them both.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-30-2013, 02:12 PM   #287
rc car guy's Avatar
No I dont gave a d3.5 but I was just wondering in comparison I was looking to get an awesome motor for my tc
rc car guy is offline   Reply With Quote
Old 11-30-2013, 02:53 PM   #288
Jerz616's Avatar
I would try the Orca if you can find one. The come with a 12.5 mm rotor and are about as smooth as you can get. The HT killshot with a HT rotor is also a good motor. You can gear it pretty tall and it still has a lot of low end and runs cool.
Ryan Gracey
XRAY XB8'14
Old 11-30-2013, 04:52 PM   #289
rc car guy's Avatar
Ya I know a guy for the orca stuff and thanks for the info ill look into it
Old 12-01-2013, 10:50 AM   #290
Trader Rating: 20 (100%+)
Default burnt motor
Originally Posted by Tommy R View Post
Well, with the advice provided here I was able to increase the timing on my RPM/RPM 17.5 Killshot. I didn't go far. I think it was just from 57* to about 60*. All during my practice sessions (upwards of 5 minutes runtime each time) the motor only got up to about 155*F and the car was very quick/fast so I was very pleased.
Unfortunately, in the first race about half way through, the car abruptly coasted to a stop, let out a big flume of smoke, and died. Looks like the motor let go, but the really bad part is it took out my ESC in the process.
It was only then that I started hearing from numerous people that this is pretty common with the Killshot motors. I'm playing it safe and going elsewhere for my next motor.
I just had this same thing happen to me last night. Killshot high RPM/HT rotor Running 17.5 blinky in a awesomatix A700L geared at 3.7 and 57* timing. I ran a couple practice runs for about 4 min, the motor temps were 155-160 and in the first qual I was in 2 min and the car came to a stop and started smoking, luckily it didn't kill my new speedo.
Maybe there was a bad batch of motors. I had the same problem when the nemesis motors came out. this is starting to make me lose confidence in trinity, im going to contact them and see if they will help me out with another motor.
Donny Banks is offline   Reply With Quote
Old 12-01-2013, 11:18 AM   #291
LonnyJ1950's Avatar
Bet I know the answer to that question.
Lonny
LonnyJ1950 is online now   Reply With Quote
Old 12-01-2013, 11:37 AM   #292
Jerz616's Avatar
I've heard that happening several times when using the HT rotor in the RPM stator. Not sure why. Haven't heard it happening yet with the HT stators.
Ryan Gracey
XRAY XB8'14
Old 12-03-2013, 06:01 PM   #293
rc car guy's Avatar
So to get a high torque stator they measure the resistant in the stator and select a higher resistant one?
Old 12-03-2013, 06:45 PM   #294
JimmyMac's Avatar
Same thing happened to me 2 weeks ago. I have a good running Killshot rpm/ht and decided to buy a second one for my other car. I ran a pack through it and motor temp was around 150ish. Started to run another pack and my car stopped on the track during practice. Motor temp was 150ish. It took out the esc. Luckily it was just a Justock and not my V3.1. Pulled the motor and spinning to rotor had a gooey feeling but the rotor wasn't touching/rubbing anything. Swapped the rotor and ends, still the same. Something up with the stator. I just hope my "good" Killshot remains good...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-29-2013, 09:52 AM   #295
edhchoe's Avatar
Trader Rating: 41 (100%+)
My killshot 17.5t went up in smoke last night as well in Seattle.
I have had it for less than a month and used it for three previous race days (9 heats).
Yesterday, it ran fine for two qualifying heats and during the main it came to a stop and smoke came out of the car. I thought it was the speedo but it was the motor.
Car is VBC d06.
FDR: 3.7
Timing: 57
ESC: Novak edge
edhchoe is offline   Reply With Quote
Old 12-29-2013, 10:34 AM   #296
Car is VBC d06.
FDR: 3.7
Timing: 57
ESC: Novak edge
How big is the track and how was the motor setup?
goots is offline   Reply With Quote
Old 12-29-2013, 04:18 PM   #297
edhchoe's Avatar
This is the track I ran two weeks ago, where the car performed just fine.
I just rechecked the FDR. in the video I had 3.7 and last night I was running 3.8 with the same 57 timing.
I am just glad my ESC survived.
+ YouTube Video
Old 12-29-2013, 06:25 PM   #298
Jerz616's Avatar
+ YouTube Video
What motor were you running. The torque or rpm version, and what rotor? I have heard of people running the rpm stator with the HT rotor and it did the same thing. What was the temp like when it let go.
Ryan Gracey
XRAY XB8'14
Old 12-29-2013, 06:26 PM   #299
JimmyMac's Avatar
Which Killshot was it? Torque? RPM? Hybrid?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 12-29-2013, 06:26 PM   #300
edhchoe's Avatar
Edit: it is purple broad power band rotor motor as it came in the box.
