Old 09-02-2013, 06:54 AM   #211
BoneCrusher's Avatar
Originally Posted by Josh-n-ya View Post
We have been running them at 58 or 59* of timing and you can start your gearing at 3.6 fdr and temp after a few minutes. I have worked down to 3.4ish fdr!
Wow. I never would have tried that high of motor timing and that low of FDR to start. But since you actually tested it, I'll give it a go.
For different track say more technical versus a free flowing one or one with a longer straight, would I adjust motor timing more or only change FDR?
What's considered the max temperature for the motor outside the can or inside the vent holes to be safe.
Your help is much appreciated!
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-02-2013, 09:12 AM   #212
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Ivan
Keep timing the same and adjust fdr. I would suggest getting a Superior Hobbies 30mm fan. Well worth the money! Keep motor temps below 160* for best results. I have been geared at 3.4 fdr and have temped motor at 120*!
Josh-n-ya is offline   Reply With Quote
Old 09-02-2013, 10:58 AM   #213
Jerz616's Avatar
Trader Rating: 49 (100%+)
Anyone have a good setup in terms of Motor Timing and FDR with the Kill Shot High RPM 17.5 stator with HT 12.5mm Rotor Brushless Motor in the Blinky 17.5 class?
Track is indoor, 36x80 ozite carpet.
Good fan used. 6 minute races.
Thanks!
Ivan
Our track is just a tad bigger then yours and I tried that combo again yesterday and I still don't like it. I was .5 slower with that combo vs. the HT/HT combo both geared at 3.8. Our track is currently set up in the IIC config and the HT/HT geared 3.8 and 58* timing is a monster. It just doesn't seem like the RPM stator is all that great. I thought it would be awesome on a flowing track but I went back to the HT/HT combo.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-02-2013, 01:31 PM   #214
Trader Rating: 20 (100%+)
You can't gear the rpm the same as the ht stator. I prefer the rpm for the track I run on.
goots is offline   Reply With Quote
Old 09-02-2013, 02:13 PM   #215
Josh-n-ya's Avatar
What would you gear a rpm at?
Old 09-02-2013, 03:31 PM   #216
The RPM stators actually look better on the dyno than the HTs do...
JamesL_71 is offline   Reply With Quote
Old 09-02-2013, 03:54 PM   #217
125' x 65' outdoor track rpm stator 12.5ht 4.0fdr 65 timing. Coming off track around 175deg.
I would have to run HT stator 12.3HT at 3.7 fdr 60 timing to get it running decent at the track I run at.
used a rs gen2 to watch internal temps and rpms around the track.
Gearing and timing depends on your track size!
Old 09-02-2013, 07:51 PM   #218
Josh-n-ya's Avatar
Wow 175*! Our track is a little smaller so temps might not be so bad!
Old 09-02-2013, 08:09 PM   #219
fyi this is an outdoor track with surface temps up to 130-140
Old 09-03-2013, 03:03 PM   #220
aloksatoor's Avatar
Trader Rating: 42 (100%+)
@Josh thanks for hooking me up with the kill shot its way smoother and higher top end than the tekin gen 2 loaner I had from my 2wd buggy!!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-03-2013, 03:33 PM   #221
Trader Rating: 16 (100%+)
142'X85'
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-03-2013, 03:37 PM   #222
aloksatoor's Avatar
I was temping at 163 sunday on norcal. One run went till 175 so I dropped fdr a bit around 3.8.
Old 09-03-2013, 06:34 PM   #223
Josh-n-ya's Avatar
No problem!
Originally Posted by Advil View Post
142'X85'
Is that what our track is? I thought of something funny to say about your measuring but wont say it!
Old 09-05-2013, 06:05 PM   #224
John Tag's Avatar
Trader Rating: 41 (100%+)
Today Trinity released the NEW ReVtech Kill Shot RPM 13.5. Now Kill Shot 13.5's are sold in either HT or RPM versions. If anybody is looking for one we have them, E Mail me at Tagstime@hotmail.com .
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,Tagstime@hotmail.com
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-05-2013, 10:39 PM   #225
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Same measurement here and my ht ht kill shot geared at 3.44 came off at 143*. That's with no fan and 127* ground temp
John any word on kill shot 21.5????????
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
SEO by vBSEO 3.5.0
