Old 08-20-2013, 05:03 PM   #196
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jerz616 View Post
Send Jim Deter an email and he will respond pretty fast. I bought both the killshots and neither fit in my T4. I sent him an email and he responded the following day and I had 2 new end bells 2 days later.
Same experience here! I had a free endbell in no-time!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-20-2013, 05:28 PM   #197
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Correction....The end bell wasnt free. You got properly made end bell that you already paid for in the mail in a few days. LOL
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 08-20-2013, 05:46 PM   #198
Lessen's Avatar
Send a message via MSN to Lessen
Is this endbell issue the reason why my timing ring is impossible to turn?
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 08-20-2013, 06:08 PM   #199
Jerz616's Avatar
Trader Rating: 49 (100%+)
No. The endbell has to do with the front screw holes drilled incorrectly to fit in some cars. Yours has to do with the timing ring on the other end. The anodizing is a little thick and makes it tight to turn. Take the timing ring off and just lightly sand around the edge once or twice. Will be perfect afterwards.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 08-22-2013, 06:51 PM   #200
sashimi999's Avatar
Hi everyone. I got one question about the shimming of the end bell bearing for my kill shot RPM.
Recently I open the motor to replace the rotor with TEP1112 high torque one.
But I forgot how many shims I suppose to put back on. So I put 3 shims (close but not touch to the timing sensor unit).
but yesterday I open my friend's Fantom Apex V2 motor (It is supposed to be identical to Kill shot motor).
it got 4 pieces shims in between.
and I feel a bit slop with my rotor.
With my friend's apex 2 rotor, I feel almost no movement inside the stator.
can I still keep my motor untouched just like this or should I open it up and add one more shim?
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 08-22-2013, 07:24 PM   #201
Josh-n-ya's Avatar
Trader Rating: 74 (100%+)
when you added the three shims did you have any left over? And where did you put them?
Josh-n-ya is offline   Reply With Quote
Old 08-22-2013, 07:47 PM   #202
sashimi999's Avatar
The HT rotor I ordered come along with 3 shims.
But for the original rotor....I can't remember because When I pulled it out, shims dropped off some ,then I can only found 3....
So I guessed it would be 3 shims on the timing sensor end.
last night my friend's Fantom motor showed up 4 shims that's why I am concern about.
::Michael C::
Old 08-22-2013, 08:08 PM   #203
John Tag's Avatar
Trader Rating: 42 (100%+)
Motors and rotors can vary on shimming. There are usually 3-4 shims on upper rotor shaft and large barrel spacer on lower pinion side of shaft on most all motors. At times from a tuner you may find 3 shims on top and 4th with barrel spacer on bottom. As long as rotor is not hitting sensor on top your ok. If motor is too tight with no free play and you cant remove a upper shim w/o sensor rubbing ,slightly sand barrel spacer to get rotor free spinning. You want a little slop not a lot..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 08-22-2013, 08:34 PM   #204
sashimi999's Avatar
yea it is not touching sensor unit.
so it is supposed to be OK. right?
May add a 4th one to the other end next time when doing cleaning.
Thanks for your answer.
::Michael C::
Old 08-23-2013, 05:35 AM   #205
idbdoug's Avatar
Trader Rating: 33 (100%+)
I know with original revtech's and D3.5's you want a total shim measurement near 1mm on sensor board side, whether that's 2,3, or 4 shims your total should be near 1mm. If too much rotor free play add shims to non-sensor side or pinion side only.
idbdoug
idbdoug is offline   Reply With Quote
Old 08-26-2013, 07:05 AM   #206
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://roarracing.org/4rmb/showthrea...llshot-T-1601T
13.5 is now ROAR legal.
syndr0me is offline   Reply With Quote
Old 08-26-2013, 08:53 AM   #207
spammy's Avatar
what do people think is the best killshot motor to run in a 12 scale?
spammy is offline   Reply With Quote
Old 08-26-2013, 12:20 PM   #208
ngo8's Avatar
Send a message via ICQ to ngo8
So which motor do you guys like better the killshot or the D3.5.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-01-2013, 10:44 PM   #209
BoneCrusher's Avatar
Default High RPM 17.5 stator with HT 12.5mm Rotor
Anyone have a good setup in terms of Motor Timing and FDR with the Kill Shot High RPM 17.5 stator with HT 12.5mm Rotor Brushless Motor in the Blinky 17.5 class?
Track is indoor, 36x80 ozite carpet.
Good fan used. 6 minute races.
Thanks!
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-01-2013, 11:38 PM   #210
Josh-n-ya's Avatar
Not 100% sure but I would say torque version!
D3.5 but since we've moved on from that I am looking forward to the D4!
Thanks!
Ivan
We have been running them at 58 or 59* of timing and you can start your gearing at 3.6 fdr and temp after a few minutes. I have worked down to 3.4ish fdr!
