Old 05-22-2013, 09:56 AM   #136
Skiddins's Avatar
Does the Revtech lightweight endbell fit? If so, it's your answer;
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-22-2013, 10:01 AM   #137
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Thumbs up
That one works also the original one and the lightweight one the josh cyrul made
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 05-22-2013, 10:44 AM   #138
It's been stated that the initial batch(es) of Killshots had the faceplate drilled incorrectly. The problem has apparently been rectified on the latest motors.
Same with the timing ring being a tick too large.
JamesL_71 is offline   Reply With Quote
Old 05-22-2013, 11:07 AM   #139
B00t13g's Avatar
Weird considering I have one motor that is an rpm and is from the original batch and a torque that isn't.(the one pictured)
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-22-2013, 01:55 PM   #140
EA posted that the first 2 batches had this problem...
Old 05-22-2013, 04:19 PM   #141
B00t13g's Avatar
Trinity is sending me new end plates. Good resolution and customer service IMO.
Mackenzie Meyercord
Old 05-23-2013, 07:19 PM   #142
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Anyone run this motor on a smaller track size, similar to snowbirds per say. 100x50? I know they ran 3.5 fdr 55degrees timing at nats, which is a decent amount bigger than what im asking. Trying to figure out how much of a gear change will be needed to keep the ol killshot from going poof. Thanks
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 05-23-2013, 07:26 PM   #143
thisguy2849's Avatar
3.5 and u will be fine at. Just run a fan
thisguy2849 is offline   Reply With Quote
Old 05-23-2013, 08:08 PM   #144
Ok, its interesting how much lower of a FDR you run with these motors and even the D3.5 than other motors in the past, but they still pass ROAR specs so they must be close. Yes the fans have improved, but 5 teeth on the pinion is a jump. The winning D3.5 at the birds (EA) was at a 3.95, thats 5-6 teeth less than what your suggesting, boggles my brain.
Xray T4
Old 05-24-2013, 05:34 AM   #145
lewis110's Avatar
The D3.5 is downright illegal therefore the increase in HP. The killshot is legal to roar specs. And also has great power from what I've heard. I believe a big increase is from the added holes for far better cooling therefore they can be pushed harder which increases HP. Jmo
Hobbywing of North America/FalconSekido www.falconsekido.com
Hobby-Pro USA www.hobbyprousa.com
Dialed RC Hobbies/VP Pro USA www.Dialedhobbies.com
lewis110 is offline   Reply With Quote
Old 05-24-2013, 06:21 PM   #146
The D3.5 was approved by ROAR as well, I hope the folks at ROAR and their infinite wisdom don't pull the same stunt again!
XRAY T3'12 17.5, Spec R R1 13.5, CRC GenXL, Grant Galloway Designs ( Painter )
lifeguy is offline   Reply With Quote
Old 05-24-2013, 09:23 PM   #147
B00t13g's Avatar
That seems insane.
Mackenzie Meyercord
Old 05-24-2013, 10:21 PM   #148
Trader Rating: 9 (80%+)
Wats The Difference Between The Killshot & Fantom Racing APEXv2
Dan-Dan Team-X is offline   Reply With Quote
Old 05-25-2013, 12:00 AM   #149
vivo quevas's Avatar
Trader Rating: 17 (100%+)
They are the same motor! Fantom tunes them and put his labels on Killshot motors. Fantom offers various options, Rotor changes between Torque or broad band rotoes and stators.
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 05-25-2013, 06:48 AM   #150
Isit Worth Getting The Works Edition Fantom Motors If So What Would Be The Best Combo for The Stator & Rotor I Run Touring Blinky
