Old 09-29-2013, 04:05 AM   #1441
Car Breaker's Avatar
Originally Posted by OVA View Post
Could be the screw is bent
I tried with brand new screws, same thing happened
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-29-2013, 08:34 AM   #1442
mutley001's Avatar
Grainger wins first leg of BRCA final round and comes 2nd to Elliott Harper in leg 2. All down to the final leg to decide the round and championship! Good luck Chris and go Schumacher!
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 09-29-2013, 09:02 AM   #1443
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Than your graphite arm is bent..check the flatness..
OVA is offline   Reply With Quote
Old 09-29-2013, 09:21 AM   #1444
mutley001's Avatar
Final leg is a win for Chris Grainger and the Mi5 which should be enough to give him the British Championships - well done Chris!
ARC R11 2017
ARC R10 2013
Team EAM
Old 09-29-2013, 09:41 AM   #1445
yokemad's Avatar
Legend!
yokemad is offline   Reply With Quote
Old 09-29-2013, 04:59 PM   #1446
TryHard's Avatar
The rear right arm of my ride are binding when it is fully tightened. This arm had met least impact than other. I wonder what happened
Check that the nub isn't running against the bulkhead, maybe just sand off a little material and the put a chamfer on the top of the nub to be sure.
Ed
Old 09-29-2013, 06:31 PM   #1447
haywood's Avatar
Trader Rating: 48 (100%+)
Default Front Spec R Gear Diff
Does someone have a link or part# for the blades I would need to run?
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 09-29-2013, 07:22 PM   #1448
TryHard's Avatar
No need, as the diff itself comes with the same sliders as used on the Schuey diffs, albeit in the grey plastic. The kit black ones fit straight on.
HiH
Ed
Old 09-29-2013, 08:14 PM   #1449
londonstylemi5's Avatar
Anybody know a good setup running the lrp flow with the x20 10.5t and reedy sonic 13.5t in the mi5? Running carpet and tarmac
Schumacher mi5, xray x12, xray t2'2007, rc10/jconcepts b4.2, old skool team Losi bk2, lrp flowworksteam, lrp x20, reedy sonic, speed passion revention pro v2, airtronics m12, savox servos
londonstylemi5 is offline   Reply With Quote
Old 09-29-2013, 11:10 PM   #1450
HiH
Ed
If you buy the schui-packaged diff, it comes with slider inserts and rings. If you buy the spec-r packaged one for mi4, it doesn't come with the slider inserts or rings, and is a wee bit cheaper.
-Mike
Old 09-29-2013, 11:18 PM   #1451
TryHard's Avatar
-Mike
I assume they both come with a spec-r header card then, as the one I picked up had sliders and all, with the spec-r header. Didn't realise there were two types.
Old 10-01-2013, 01:10 PM   #1452
Tried to reassembly my geardiff yesterday to try to get it stop leaking. The o-rings were intact, and everything seems to be in the right order.
But it still leaks like crazy, any idears how to get it to stop, I have a race this weekend, and hoping to solve this before.
Any surgestion will be helpfull.
Shock Tower is offline   Reply With Quote
Old 10-01-2013, 02:14 PM   #1453
There's this one, which is the Schumacher part number (but clearly looks to be packaged by Spec-R.. it's been a while since I bought one):
http://www.amainhobbies.com/product_...r-Differential
But there's also this one, which is actually quite a bit cheaper:
http://www.spec-r.com/default/index....roducts_id=209
-Mike
Old 10-01-2013, 05:53 PM   #1454
Trader Rating: 23 (100%+)
mine was like that too. ended up running an extra o-ring and it hasn't leaked since. just remember to check and change your shims accordingly.
hope this helps.
poop is offline   Reply With Quote
Old 10-01-2013, 06:33 PM   #1455
something bent or deform in the arm, a new one fix everything.
Xray X12 2015
ARC R10 ATS
SEO by vBSEO 3.5.0
