Like Tree21Likes
Old 09-25-2013, 10:03 PM   #1426
DiscountRCStore's Avatar
Originally Posted by haywood View Post
Ran the car finally for the first time tonight... Right on pace with Hofers setup! Broke the stock servo horn in the main so what do you guys recommend for the servo horn or servo saver?
We've used both the Xray extra stiff and the Tamiya 51000 ( or 84082 ) with good success ... Core RC CR192 for a standard horn is perfect! hope it helps ..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 09-26-2013, 01:27 AM   #1427
im sticking to very bog standard servo horns as id rather they strip than the servo going bang
PurcyP is offline   Reply With Quote
Old 09-26-2013, 03:11 AM   #1428
yokemad's Avatar
Originally Posted by JayBee View Post
Some guys can get away with running the stock servo horn....I couldn't. Stripped 2 of them one weekend. Servo savers for me typically. First car I ever tried to do that with. My suggestion is one of the 2 XRay options.
how was it compare to a700?
Cheers...
yokemad is offline   Reply With Quote
Old 09-26-2013, 04:04 AM   #1429
The Teacher's Avatar
Trader Rating: 47 (100%+)
Why don't any of you guys run the Schumacher servo saver? This is what I run and feel that it is just as good as the xray servo saver...
The Teacher is offline   Reply With Quote
Old 09-26-2013, 04:19 AM   #1430
They don't have them in stock, and haven't had them for 8-10 weeks, and they will no be in stock for a while.
Shock Tower is offline   Reply With Quote
Old 09-26-2013, 06:50 AM   #1431
poochy's Avatar
how does the schuie gear diff hold up (leakage)?
does the mi4 specR gear diff fit in the rear?
poochy is offline   Reply With Quote
Old 09-26-2013, 07:03 AM   #1432
Car Breaker's Avatar
SpecR diff cannot be used in the rear but front of Mi5, the stock gear diff seem fine against leaking
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-26-2013, 07:31 AM   #1433
Except if you overfill it. My leaks alot now, but I think it is because I filled it above the recomended level.
Old 09-26-2013, 08:36 AM   #1434
JayBee's Avatar
Trader Rating: 31 (100%+)
Cheers...
If you're talking about the cars, my MI5 was a beautiful piece of machinery. I wanted 2 cars and had to decide between the two. I chose my shelf queen (really because I hadn't ran it before). Plus, for VTA/Scale Spec...it kind of a no brainer. The drivetrain is super efficient. Just need another for 17.5.
Don't wanna hijack the thread so back to the MI5.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-26-2013, 10:02 AM   #1435
poochy's Avatar
please keep me posted.
also i have read about slop in the arms ball cup (not the castor/kingpin slop)...is this resolved?
Old 09-26-2013, 10:30 AM   #1436
I will do,
Actualy I hope that when the excess olie is come out, that it stops leaking. But maybe I will need to pull it apart again, and then empty some of the oil.
Actualy it was only a little excess oli I filled in, but aparently it was to much.
Havent discovered any slop, beside the slop in caster blocks.
Old 09-27-2013, 07:49 AM   #1437
olhipster1's Avatar
Trader Rating: 95 (100%+)
Send a message via Yahoo to olhipster1
Default New parts
new still chassis released today.
looks like it includes the inner arm braces.
http://www.racing-cars.com/pp/New_Ca...Mi5/U4398.html
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-28-2013, 08:28 PM   #1438
Scheduled in stock 10/2/13, pre-order available!!
http://www.discountrcstore.com/Schum...et_p/u4398.htm
..p
Old 09-28-2013, 09:20 PM   #1439
The rear right arm of my ride are binding when it is fully tightened. This arm had met least impact than other. I wonder what happened
Xray X12 2015
ARC R10 ATS
Old 09-28-2013, 09:48 PM   #1440
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Could be the screw is bent
OVA is offline   Reply With Quote
