Like Tree11Likes
Old 09-02-2013, 06:21 AM   #1306
Originally Posted by CA View Post
This is wrong info i'm afraid, cutting the shock shaft will not affect the rebound.
The shock shaft is not too long its just that some drivers prefer to have the piston slightly lower in the shock body.
It doesn't make a huge difference.
Thank you for informing me, I was led to believe that it did touch the diaphragm giving a rebound of the rubber returning to its shape and pushing the shaft back out...
What does running shorter shafts give u? I appreciate it's only a mm or so difference between cut and uncut but when it's only a small volume shock body a mm x 3mm in volume would change the pressure inside a shock body a fair bit I have no experience of shortening my shock length as feel I can improve other things first before I will feel a difference in shock length.
Jampot is offline   Reply With Quote
Old 09-02-2013, 06:24 AM   #1307
keeping on the topic of shocks
ive got a load of shock piston "discs" of varying holes from 1 2 3 and 4..I use 40wt oil front and rear, what effect will the different holes have
PurcyP is offline   Reply With Quote
Old 09-02-2013, 07:44 AM   #1308
DiscountRCStore's Avatar
Generally, they will affect the shaft speed ( faster, less pack = bigger.. more holes) or ( slower, more pack = smaller .. fewer holes) Oils can be used similarly. This is a very simplified explanation..
read here: http://users.telenet.be/elvo/
Section 2.2 under 'Suspension' for a full explanation.. Hope it helps! ..
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 09-02-2013, 10:10 PM   #1309
Car Breaker's Avatar
Look nice, too bad I already got mine. Wonder what you don't satisfied with it ?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 09-03-2013, 01:54 AM   #1310
CA
They cut only 2mm, it won't change any pressure or anything like that. I'm almost certain you wont feel any benefit on the track. Its just a matter of having the piston a little further down in the body.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 09-03-2013, 12:22 PM   #1311
poochy's Avatar
does anybody run rw spur gears? any good?
poochy is offline   Reply With Quote
Old 09-03-2013, 02:40 PM   #1312
haywood's Avatar
Trader Rating: 48 (100%+)
Default Shock shaft
Is it 2 or 3mm to cut the shaft?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 09-03-2013, 09:44 PM   #1313
Yes.. they are quite good.. made from delrin.. very durable, perfectly round and abit more quiet than the stock ones.
News on the the the new steering blocks and king pins..Here's an excerpt from Mark's email to us today..
"... the new parts are U4256 Front hub carriers and also U4270 the King Pin and Spacer. They are the same price as before and have replaced the existing parts. People will know they have the new parts as on the description on the header card it says V2. If it doesn’t say this, then it is the original version...."
We will be getting these in stock very soon.. drop us a line if you're needing them. . they'll be on site in a day or so..
Old 09-03-2013, 10:46 PM   #1314
Dusttt's Avatar
Trader Rating: 118 (100%+)
Actually the car is great just a case of too many cars and not enough time
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 09-05-2013, 09:02 AM   #1315
Trader Rating: 38 (100%+)
INPUT PLEASE. Can anyone share how realiable the MI5 is? I had a Xray T3 and T4 and found them very durable. Just curious with the carbon arms etc. thanks.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 09-05-2013, 10:02 AM   #1316
jdm19turn's Avatar
i have been running the car for a month or more and i have been hit several times and haven't broken nothing on the car and i done all the suggested mods it's been very durable so far to me
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 09-05-2013, 10:24 AM   #1317
jdm19turn's Avatar
if you could send me a pm once you got them instock and I'll place a order
mi4 ,mi5
Old 09-05-2013, 10:34 AM   #1318
Running it outdoors on asphalt all summer with some tough track barriers. I've broken the aluminum screws anchoring the front arms a few times, 2 of the old style knuckles, and ..... that's it.
This car is tough, and I can be really hard on cars.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 09-05-2013, 03:10 PM   #1319
haywood's Avatar
Anyone?
Old 09-05-2013, 03:23 PM   #1320
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Anyone?
According to Martin Hofer's build blog (for the ultimate in performance), it's 3mm approx. See here: http://hofaaa.wordpress.com/2013/06/...ortance-of-5p/
Lots of good tips there.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
