Like Tree11Likes
Old 08-29-2013, 11:41 PM   #1291
mutley001's Avatar
Originally Posted by haywood View Post
Hofer's setup has the shock length at 10mm not 12mm like the kit suggests. Is this achieved by cutting the shafts our by limiting with o rings or spacers?
I went with spacers - seems to handle just great
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 08-30-2013, 03:32 AM   #1292
DiscountRCStore's Avatar
The shafts are cut ( by 3mm ) and then usually set up at 10.5mm in length..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 08-30-2013, 04:52 AM   #1293
I cut the shaft and its easier to setup and handle smoother I find
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 08-30-2013, 06:54 AM   #1294
If u don't cut the shaft u get difference in pack and u also get the shock shaft hitting the membrane which effects ur rebound
Jampot is offline   Reply With Quote
Old 09-01-2013, 10:09 AM   #1295
Anyone tried the cut wishbones for themselves yet,did you cut just fronts or rears too and was it better?
Quietman is offline   Reply With Quote
Old 09-01-2013, 10:43 AM   #1296
how the hell do you rebuild the shocks without getting air in em, still cant manage it :|
oh well lol
ran my mi5 today came 3rd overall, very pleased, i love the car its so forgiving to drive.
PurcyP is offline   Reply With Quote
Old 09-01-2013, 11:16 AM   #1297
Potoczak's Avatar
Trader Rating: 109 (100%+)
Its not easy building the schumacher shocks.. I have watched the video of Chris building the shocks and have done exactly like he does and still can't get minimal rebound.. Maybe the trick is cutting the shock shafts..
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-01-2013, 11:56 AM   #1298
Have you tried a shock pump,just started using one about a month or two ago shocks seem easier to build.
Old 09-01-2013, 02:45 PM   #1299
If u have not cut the shock shaft u won't get 0 rebound.
The top of the shaft hits the bladder if it hits the bladder it will rebound out. Or use an o ring as an up stop!
Old 09-01-2013, 03:48 PM   #1300
Potoczak's Avatar
So what's better cutting the shaft or using limiters inside the body??
Pete Potoczak
Old 09-01-2013, 06:04 PM   #1301
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
It's easiest to use dremel cutting disk and take off 2-3mm off the bottom of the shaft.
It is all about the position of the piston and how it affects pack. It also is a problem if the shock is too long and touches the bladder under full compression.
The boys at HB have been doing for ages...
But the schuie shafts are too long from kit. Hence why MH posted to cut them and make the distance 10.6mm from bottom of shock body to top of ball end.
HTH.
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 09-01-2013, 06:06 PM   #1302
I have cut both frt and rr wishbones. I orginally cut the frt only and liked them. I have also cut the rr now and also liked the way the car felt and handled. I race on large outdoor tracks that are bumpy.
Old 09-02-2013, 01:02 AM   #1303
But , if you cut the shaft the droop is modified also. ??
You need the lowered shock supports????
JordiM is offline   Reply With Quote
Old 09-02-2013, 02:16 AM   #1304
Correct, it affects droop and adjust accordingly. I run mine at 5/4 frt/rr (under outer hinge pin).
And it because the kit shafts are too long to begin with. There is no need to for lowered shock towers when doing this mod.
HTH
Old 09-02-2013, 05:50 AM   #1305
CA
This is wrong info i'm afraid, cutting the shock shaft will not affect the rebound.
The shock shaft is not too long its just that some drivers prefer to have the piston slightly lower in the shock body.
It doesn't make a huge difference.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
