Old 08-27-2013, 07:18 PM   #1276
chiefj48's Avatar
Originally Posted by tcboy1983 View Post
its a carbon braces only on the rear arms and they go from the top of the wishbone ball studs linking the front ballstuds together and rear ballstuds together (guessing use a longer screw so it pops out the top then u can use a nut to hold the brace on )
are they a special order item, or is it something we need to make ??? it seems like they would have to clear the belt, and diff....
Get us a SPY shot!!!!!! lol
chiefj48
Home of the; 2016 ROAR On Road Asphalt Nationals
Special Thanks to , Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 08-28-2013, 02:35 AM   #1277
Sorry no pics I saw this at the btcc And brca nationals
Alloy screws would save ur chassis yes but I have cut the wishbone and just going to see if its strong
these are the arms i did
What difference did you notice doing this?
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
Old 08-28-2013, 05:03 AM   #1278
Yes the do have to clear as if its straight it hit the diff at the front and it has to go around the bulkheads at the bk
I can't take a pic as there is no more nationals this year at my track sorry
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 08-28-2013, 05:04 AM   #1279
Nothing yet as only just done i was just showing how I cut the arms like some of the team drivers did
all or nothing
Old 08-28-2013, 09:00 AM   #1280
, keep us up to date on how it goes for you.
Old 08-28-2013, 10:01 AM   #1281
DiscountRCStore's Avatar
Here's your spy shot, we're working to get some of these in stock, as well as the shock mounts... Stay tuned
The second pic, view from the top shows the front of the rear arms linked together with a carbon brace..
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 08-28-2013, 10:56 AM   #1282
thats what i was talking about but only running the front brace cool
also is that the short shocks and lower still shock tower that martin hoffer uses ?
all or nothing
Old 08-28-2013, 12:08 PM   #1283
chiefj48's Avatar
Hey Phil
You know I need a set for my car, right????
Lol
chiefj48
Old 08-28-2013, 01:00 PM   #1284
One of my guys has been in communication with Martin. .. it seems, at least for now, that the shorties will not be an 'official' option for the 5... however if there's significant interest , we may/ could look into having the towers produced locally..
@ chief... no problem. . When they're in our hands, I'll be letting you know..
..p
Old 08-28-2013, 01:52 PM   #1285
Hi guys, had my first outdoor evening racing the mi5 tonight, loved it, came 3rd overall
Edit: found out the motor issue, ive sheared my sensor wire in half haha was running sensorless
but in terms of spur, i am using a 48 pitch 70t with a 28t pinion, i dont feel its fast enough, with full timing advance on the motor, its barely getting warm, any ideas, would rather stick to 48p as the smaller style spur keeps any stones from ripping it up to a minimum.
PurcyP is offline   Reply With Quote
Old 08-28-2013, 02:12 PM   #1286
..p
Phil, sent you a pm,
Rich
gdcopbdcop is offline   Reply With Quote
Old 08-28-2013, 03:09 PM   #1287
chiefj48's Avatar
..p
Thanks Bud......
chiefj48
Old 08-28-2013, 03:15 PM   #1288
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Using a plastic horn saves ur expensive servo
So u get all the advantage of not running a servo saver but still stops ur servo braking the internal gears , u can get a alloy one but if u make something stronger something else will brake
Certainly that's a given. I'm just into taking a hit and have the horn strip and skip a few teeth, throwing the steering way off to one side during a race.
.....was just asking the question if there were other options out there being used. Thanks.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 08-28-2013, 03:58 PM   #1289
Use the servo saver but they don't always go bk to dead centre plus cause the steering to be lazy to react
I have had a servo horn or two go on me and didn't find anything that give the dirct feel and cost less if it brakes
all or nothing
Old 08-29-2013, 08:55 PM   #1290
haywood's Avatar
Trader Rating: 48 (100%+)
Default Shocks
Hofer's setup has the shock length at 10mm not 12mm like the kit suggests. Is this achieved by cutting the shafts our by limiting with o rings or spacers?
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
SEO by vBSEO 3.5.0
