Like Tree20Likes
Old 08-26-2013, 10:48 AM   #1261
Trader Rating: 24 (100%+)
Default ackerman
can you adjust ackerman on this car? I cant figure out how to do so or am i just missing something?
gocoogs is offline   Reply With Quote
Old 08-26-2013, 02:35 PM   #1262
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Is there a preferred servo horn out there other than the stock plastic one? I ran the car on carpet for the very first time (USVTA oval racing) and it was dialed missed TQ by .04 and thanks to a lapped car, I finished 2nd. However, during practice I hammered another car as he slid out going into turn 1 and the servo horn skipped and stripped a bit. I definitely need to get something more robust. Ideas? I know there are aluminum options but do those come with some sort of "saver"? Thanks in advance.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 08-26-2013, 03:21 PM   #1263
DiscountRCStore's Avatar
Finally had time to run the car for the first time. Only one problem.. I've never run outside on asphalt. I wanted to try the mid motor conversion first. This car was amazing right from the start! I did make some small changes every run and the car got faster and easier to drive. Better than my Xray T4 first time out as well! Cant wait to start the racing season!
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 08-26-2013, 03:34 PM   #1264
The only way to adjust that is the 2 outside holes on the carbon steering arm.
Old 08-26-2013, 04:42 PM   #1265
pbr
Scott that Mi5 sure looked good in VTA sure made for some close racing . We really like the USVTA rules . Have you tried that car in TC 17.5 yet ? If you have what's your thoughts ?Also how is the parts support? Thanks
Paul
pbr is offline   Reply With Quote
Old 08-26-2013, 04:58 PM   #1266
chiefj48's Avatar
Originally Posted by tcboy1983 View Post
To help the rear ones I have seen a brace from the ball studs like two strut braces to aid in stopping the rear screws pulling though
Can you provide pictures of the rear braces????
would it be safe to use the alloy screws in the rear to prevent the screws from pulling through???
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 08-26-2013, 05:40 PM   #1267
Running Martin's standard setup on asphalt and the car is amazing on the sweepers and on the straights. Only thing is I am looking for just little more steering on the tight sections of the infield without changing the high speed handling. Any suggestions on what I should try?
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 08-27-2013, 03:56 AM   #1268
Using a plastic horn saves ur expensive servo
So u get all the advantage of not running a servo saver but still stops ur servo braking the internal gears , u can get a alloy one but if u make something stronger something else will brake
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 08-27-2013, 04:01 AM   #1269
Sorry no pics I saw this at the btcc And brca nationals
Alloy screws would save ur chassis yes but I have cut the wishbone and just going to see if its strong
these are the arms i did
all or nothing
Old 08-27-2013, 04:26 AM   #1270
the uk team were testing new carbon steering arms also
all or nothing
Old 08-27-2013, 05:34 AM   #1271
chiefj48's Avatar
TCboy
Please let us know how it works and how the changes Make the car feel.
Can you better explain what the braces look like, what they r made of, and where they are attached to??
Thanks for all your information.
chiefj48
Old 08-27-2013, 06:12 AM   #1272
Trader Rating: 38 (100%+)
Hi everyone. FOR SALE. My bad luck. Local track shut down the day after I finished building. Because of my work I have no other place to use the car. NEW MI5 with mid motor conversion (standard included/rear). call me text me. 518-495-0703.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 08-27-2013, 06:46 AM   #1273
Hey Corey,
Found that I would need a little more steering out of the corners last time I ran at Ottawa. Was thinking to try 6° caster to see how it goes.
Martin
rhodopsine is offline   Reply With Quote
Old 08-27-2013, 09:40 AM   #1274
TCboy
its a carbon braces only on the rear arms and they go from the top of the wishbone ball studs linking the front ballstuds together and rear ballstuds together (guessing use a longer screw so it pops out the top then u can use a nut to hold the brace on )
all or nothing
Old 08-27-2013, 11:54 AM   #1275
SOLD> THANK YOU.
