Like Tree34Likes
Schumacher Mi5
Old 08-10-2013, 09:00 PM
  #1201
with the shorter shafts, you are able to set your droop properly, and not have your shocks be pre-loaded by the droop screws. makes setting your droop way easier. (this is just my opinion)...
gdcopbdcop is offline
Old 08-10-2013, 10:55 PM
  #1202
mutley001's Avatar
Originally Posted by gdcopbdcop
the kit has the distance from the bottom of the shock body to the top of the ball cup at 12 to12 1/2 mm. Martin Hofer's setup has the distance at 10.5 mm. The only way to get to the shorter distance is to cut the shock shaft (on the threaded end) 3 mm. I cut mine with a dremel tool. works great.
I just put a 2mm shim on the shock shaft inside the shock so it couldn't come out as far - works for me
mutley001 is offline
Old 08-11-2013, 12:15 AM
  #1203
Maybe a stupid question, but when you are using the Yokomo spring on standard lenght shocks, then it seems like there is no room for shortining the lenght of the springs ?
So I would think, that if I took 3 mm off the lenght, then there would be preload on the springs, even when they were not mounted on the car.
Woulden't that be wrong ?
And again, maybe I am totally wrong.
Shock Tower is offline
Old 08-11-2013, 12:48 AM
  #1204
Ask AdrianM, he has used the yoke springs on carpet. I haven't used them yet.
Old 08-11-2013, 05:46 AM
  #1205
mutley001's Avatar
You're right the is a little preload but the car drives great so I'm not bothered about it
Old 08-11-2013, 11:27 AM
  #1206
Originally Posted by dorkmissle
Hi, ran my Mi5 for the first time tonight on med grip carpet. Car was pretty good out of the box. Lots of steering. A little skaty on power (could be my 4.5t and heavy trigger finger) Looking to get yok springs and go up on oil a bit. might need less rear toe. Only wish the diff height could be adjusted.
Try putting the diff cams on the opposite side to kit
Quietman is offline
Old 08-11-2013, 01:22 PM
  #1207
Is there anyone who has checked toe in rear. On my car it is 3 degrees on right and 4 degrees on left.
mik1903 is offline
Old 08-11-2013, 02:15 PM
  #1208
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Due to the tight tolerances, the car can give toe settings that are out. What you need to do when tightening up the arm mounts are:
1. Don't tighten screw fully initially
2. once firm but not tight, use the wrench supplied
3. make sure you tighten the arm mount nuts using the wrench (ie. on the left side turn the wrench towards the same way on both screws and repeat on the right side)
4. if it is still out, gently loosen a little and repeat.
This should hopefully get the arms aligned properly.
HTH.
Leonard.
DirtyDog3375 is offline
Old 08-11-2013, 02:16 PM
  #1209
Yes, droop can be set properly when using the shorter length shock shafts (ie. MH 10.6mm)
Old 08-11-2013, 02:18 PM
  #1210
Not checked mine since built sure mine was spot on,have you got a damaged screw??
Quietman is offline
Old 08-11-2013, 02:34 PM
  #1211
all screw look fine
mik1903 is offline
Old 08-11-2013, 03:46 PM
  #1212
I read Martin Hofer's latest blog. In it, he mentioned cutting the front arms. Does anyone have an idea of where they were cut, how much was cut,and why?
Old 08-11-2013, 06:42 PM
  #1213
scott_g's Avatar
They're cutting through and removing a section from from arm between inner mount screws. Lets the arm flex and improves stability under brakes.
I have seen one done, but yet to try myself. Don't have photo sorry.
scott_g is offline
Old 08-12-2013, 12:52 AM
  #1214
HTH.
Leonard.
i will try this thanks for help
mik1903 is offline
Old 08-12-2013, 02:28 AM
  #1215
+1!!!
