Like Tree21Likes
Old 08-03-2013, 06:45 AM   #1156
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by Shock Tower View Post
Maybe this is an general question, but since the problem is on my new Mi5, I will postbit here.
My problem is to getting the rear swaybar adjusted right. The one side is lifting normaly up, but the other don't make the opposite side move at all ?
I have measured the swaybar links attached to the wishbone, and the are excatly the same lenght. The angel of the swaybar links is also 90 deg as stated in the manual. Without the swaybars links attached to the swaybar, the seaybar are moving freely, and without no sloop.
I have checked the swaybar on my setup board if it is straight, and it seems like it.
So I don't have any more ideas, anyone who have a good advice ?
Shock tower: in the sway bar links pack they give you 3 grub screws, 2 of them have points on the end and 1 is flat on the end. Make sure you use the flat grub screw for the centering collar in the middle. And the grub screws with the points go in the plastic holders.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-03-2013, 06:55 AM   #1157
chiefj48's Avatar
Originally Posted by gdcopbdcop View Post
leave the ball cup alone. cutting the shaft is enough....
Thank you.....
what about the .3mm shim for the seal unit????
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 08-03-2013, 07:25 AM   #1158
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by miguelito75 View Post
The best way i found to build my shocks with no rebound is to drill a hole in the plastic shock cap. Just a 0.5 mm will do the job.
This is what I do as well.
IIGQ4U is offline   Reply With Quote
Old 08-03-2013, 12:57 PM   #1159
When do you use rebound and when do not use it,somthing i have not really understood,basiclly whats it used for always run none,but like to know anyway.
At euros chris said about a brace there testing and lower shock towers and think they said shocks too,
Quietman is offline   Reply With Quote
Old 08-03-2013, 01:30 PM   #1160
Potoczak's Avatar
Typically you run more rebound if your on a low grip track. If traction is high then minimal rebound. Or if your track is bumpy then run more rebound
Pete Potoczak
Old 08-03-2013, 01:40 PM   #1161
Thanks for the hint. I checked that also, and no problem there. I talked to another RC friend, and he told me to try adjusting the lenght of the sway bar links.
I shorten one of the links, and now both side works as they should. So there must be some tweak in the swaybar, that I coulden't see even when I laid it flat on my setup board.
Shock Tower is offline   Reply With Quote
Old 08-03-2013, 02:40 PM   #1162
Old 08-03-2013, 04:23 PM   #1163
Potoczak's Avatar
Does anyone soak their belts is wd-40 to soften them up?? If so how long??
Pete Potoczak
Old 08-04-2013, 05:13 AM   #1164
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Another option if you're running in a spec class is to pick up a set of the grey belts (U3012/U3013) which are already softer...
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 08-04-2013, 05:25 AM   #1165
At the euro's today. So far i have spoken to Chris and Martin. Both very nice and helpfull. The cars are pretty standard! They are running a new Brace that attachés the front of the rear arms. And a couple of small things.
miguelito75 is offline   Reply With Quote
Old 08-04-2013, 07:49 AM   #1166
NITROmmm's Avatar
Thumbs up
Scott g is on the money, I use these belts on my mi5 running 17.5 boosted and the car is very "free" and feels a lot smoother. As with all belts keep an eye on the tension.
miguelito, what is that brace?
He who laughs last, thinks slowest!
RC HOBBYZONE
JSPECSTICKERS
NITROmmm is offline   Reply With Quote
Old 08-04-2013, 03:14 PM   #1167
Potoczak's Avatar
This question is for the guys that run the orca batteries in the mi5. What are you guys doing with the inner battery post. With the battery in the car it is almost under the top deck. It cannot be pulled out without taking the battery out. I like to charge my batteries with them in the car. Anyone have any idea's on how the acomplish this??
Pete Potoczak
Old 08-04-2013, 04:58 PM   #1168
haywood's Avatar
Trader Rating: 48 (100%+)
I have the same problem. I will have to remove it and charge it in a lipo sack.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 08-04-2013, 05:08 PM   #1169
haywood's Avatar
Who makes and sells that purple battery tape?
Old 08-04-2013, 05:11 PM   #1170
JayBee's Avatar
Trader Rating: 31 (100%+)
After this weekend of racing (total runs on the car is between 18-22 and a couple of major crashes and bumps/bruises along the way), I've found about .75-1mm of vertical play in my front arms. The CF is perfectly fine but has anyone found an effective way of removing the glue-in inserts in the arms?
I wonder if there was a way to have the inserts attached w/o ca'n them...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
