Like Tree21Likes
Old 07-24-2013, 01:17 AM   #1006
JayBee's Avatar
Trader Rating: 31 (100%+)
For droop #'s on the setups in the manual (or for that matter all of the current setup sheets), are they using the 10mm blocks? I don't see the box checked off
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-24-2013, 01:59 AM   #1007
Originally Posted by olhipster1 View Post
turn the gauge North-South and measure.. gauge currently is facing West -East.
Why didn't I think about that :-) off course, that proberbly work. Thanks, coulden't just not see what the f... I should do.
Shock Tower is offline   Reply With Quote
Old 07-24-2013, 02:05 AM   #1008
Originally Posted by John.C View Post
+1
If I had to measure down stop, I would measure from the center of the axles with digital calipers. For simplicity, I would measure from the top of the axle to the setup board and subtract half of the thickness of the axle + height of support blocks. I don't see a need for it, but if you choose, you can than compare this value against any touring car.
I am not used to measure droop, so I am actauly not sure how to. I have read in the Xray setup manual, but dosen't quit see that downstop is not needed for also the droop adjustment. Maybe I will look at the tube, for an explanation.
Old 07-24-2013, 02:07 AM   #1009
scoyle's Avatar
I was told that they are doing it flat on a setup board with a ride height gauge. Personally I use 10mm blocks and a normal hudy droop gauge.
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 07-24-2013, 08:34 AM   #1010
I use the ride gauge in North/South mode as well with wheels off on a flat surface but some of the chassis screws in my build are not perfectly flush so my chassis won't sit perfectly flat. I think the alloy front wishbone screws are the culprit. I may try a different brand screw as an easy fix.
DavidNERODease is offline   Reply With Quote
Old 07-24-2013, 12:11 PM   #1011
Send a message via ICQ to MattW
The diff cams on those pics of Martin's car are Mi4 ones that have been modified. Un-modified Mi4 ones WILL NOT fit straight in to the Mi5.
MattW is offline   Reply With Quote
Old 07-24-2013, 12:35 PM   #1012
Potoczak's Avatar
Trader Rating: 112 (100%+)
You are correct! They do not fit. They dont slide all the way back to sit flush with the bulkhead..
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-24-2013, 12:44 PM   #1013
scoyle's Avatar
Is Martin just running them because they are purple or is there some other reason?
Old 07-24-2013, 01:16 PM   #1014
he likes the purple
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 07-24-2013, 03:29 PM   #1015
scoyle's Avatar
What difference does it make moving from the 4 groove link plate to the 3 groove?
Old 07-24-2013, 04:27 PM   #1016
haywood's Avatar
Trader Rating: 49 (100%+)
+1
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-24-2013, 04:28 PM   #1017
DiscountRCStore's Avatar
Allows you to run a shorter camber link = more (quicker) camber gain under compression..
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 07-24-2013, 10:01 PM   #1018
Got my kit today, cant wait to start building then racing
13art is offline   Reply With Quote
Old 07-25-2013, 06:56 AM   #1019
silvalis's Avatar
Trader Rating: 29 (100%+)
Anyone tried using the bigbore touring shocks? Pointless?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 07-25-2013, 08:24 AM   #1020
I also don't understand the point of the big bore shocks.
