Old 07-23-2013, 09:23 AM   #991
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Originally Posted by jackcarter3 View Post
Gearing question. Medium size outdoor and indoor asphalt tracks. Will be running 10.5 mostly with the stock spur. What pinion range? I also may toss a 4.5 in it now and then just for kicks. What pinion range there also with the stock spur?
Thanks for any feedback. Soldering up the car today and didn't have time to read this whole thread.
Running reventon pro esc and sp motors.
4.5t motor you can start around 19/85. Monitor temperatures closely.
10.5 I don't know sorry.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 07-23-2013, 09:44 AM   #992
jackcarter3's Avatar
Ok thanks. I hate posting up gearing questions but was in a hurry. I will start there and temp. I noticed a set up that was a 5.5 89 / 21 so I was way off in my guessing for an 85.
TEAM SCHUMACHER-USA
TRACTION RACEWAY-Reno, NV.
jackcarter3 is offline   Reply With Quote
Old 07-23-2013, 11:04 AM   #993
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by The Teacher View Post
Cpt.America, check and see if it's your piston rubbing the sides of your shock body. Maybe the shock shaft is at a weird angle when it is being compressed making the piston scrape against the side of the shock body. The shock will need to be mounted on the car to check this. Look to see if when compressed the shock shaft shifts in the shock body. I've had this happen when my O-rings are shot or when I build the shocks wrong..
It follows the rear of the car, not the shock or the piston. If I swap shocks front to back, it still happens in the rear, and not the front. Off the car, the shocks feel flawless. ON the car, the fronts feel flawless, the rears go "tick tick tick tick" on their way up.
It's not the shock, or the springs. I've tried 3 different sets of springs (not to try and fix this, just in playing/tuning). The only thing I can think of is that either:
A) the control arm actually IS making contact with the bulkhead somewhere, and I didn't remove enough material... and having the shock mounted is what puts enough pressure on the system to make the contact (considering the arms feel perfect with no shock mounted)
or
B) With the shock mounted, there is some strange pressure happening on the pivot balls, making some sort of stiction.
I guess ill try putting a tiny drop of oil down into the pivot balls... then try removing more material from the inside of the control arms.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-23-2013, 11:28 AM   #994
olhipster1's Avatar
Trader Rating: 90 (100%+)
Send a message via Yahoo to olhipster1
or
A. put a piece of paper on bulk side of arm and move the arm up/down. if it marks then shave a bit more.
B. why not take the pivot ball out of the bushing..perhaps a drop of CA fell on one side, etc. clean off i(if Yes)...then try again.
C. Long shot but perhaps drop screw isn't set right in the bushings...not probable but worth checking.
too many variables...best to just take apart, it's prob something minor with an easy fix.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 07-23-2013, 11:58 AM   #995
Which position have you on the geardiff and spool for belt tension. Are you using the standard position (white dot) ?
I think the standard dot seems a little to tight for the front belt, ore am I wrong ?
Anyone knows and maybe can link to shims for adjusting the ball studs on the suspension links, and also shims for inside the shocks for removing play.
Shock Tower is offline   Reply With Quote
Old 07-23-2013, 03:01 PM   #996
How do you measure the downstop on the new Mi5. I am used to measure underneath the C-hub, but the new design of the plastic part of the wishbone, make it very difficult. I tried to take a Picture about what I mean, hope it make it more clearly. The arrow shows where the plastic part is in the way for the downstop measure Tool.
Old 07-23-2013, 03:21 PM   #997
olhipster1's Avatar
turn the gauge North-South and measure.. gauge currently is facing West -East.
CAUSE and EFFECT
Old 07-23-2013, 03:24 PM   #998
Jon Williams's Avatar
What are you doing in this thread?! Git!
You have one car that you are currently doing well with!
Jon Williams is offline   Reply With Quote
Old 07-23-2013, 03:26 PM   #999
Super Moderator
I myself never measure downstops... Just ride height, and droop.
- RCSpecialties -
Old 07-23-2013, 03:58 PM   #1000
scott_g's Avatar
I had to set the belt tension a little looser than standard for first few runs in spec. Now running at the white dots in Mod TC. If it's too tight, loosen it a notch or two, just keep an ear out for it, check regularly and tighten if necessary. Usually first place you'll hear skipping is under brakes.
Martin Hofer's website has an excellent build article with tips about shimming, removing slop etc. Article is here: http://hofaaa.wordpress.com/2013/06/...ortance-of-5p/. Basically for shocks he says:
- superglue piston to shaft, or use 0.1mm shims
- 0.3mm shim between shock seal and spacer (4mm inside dia I think)
- also cuts 3mm off shock shaft to shorten overall length
It's a good build article and shows the little extras that can be done to make the tiny differences for a pro-level build.
Old 07-23-2013, 05:02 PM   #1001
John.C's Avatar
Trader Rating: 36 (100%+)
+1
If I had to measure down stop, I would measure from the center of the axles with digital calipers. For simplicity, I would measure from the top of the axle to the setup board and subtract half of the thickness of the axle + height of support blocks. I don't see a need for it, but if you choose, you can than compare this value against any touring car.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 07-23-2013, 07:26 PM   #1002
Potoczak's Avatar
Trader Rating: 107 (100%+)
Hey guys on the pics from Martin hofers car what eccentrics is he running on his car?? Are they from a mi4?? They are the purple ones.
Link to that page with the pics.
http://ets.redrc.net/page/10/
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-23-2013, 08:13 PM   #1003
olhipster1's Avatar
darn....i thought no one ever look to see if I was here.
Going to drop a mod in and see if she "Go Fast"
CAUSE and EFFECT
Old 07-23-2013, 09:02 PM   #1004
scott_g's Avatar
I dont know for sure, but two things:
- probably a pre-production car - production mi5 didn't arrive until after that date
- he has said he likes replacing black with purple where possible - so if mi4 eccentrics fit (which I haven't checked...but bulkhead spacing and bearing size are the same...so probably they do) he might be running them just for the colour
Edit: Mi4 eccentrics don't fit properly into the bulkhead (advise from Schumacher), Martins were modified to fit
Old 07-23-2013, 09:36 PM   #1005
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Correct Scotty G! They do fit...I contemplated it when kitting out my purple Mi5, but thought they would get too dirty, so kept that black.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
