Old 07-20-2013, 03:06 AM   #961
sosidge's Avatar
Originally Posted by linkless View Post
Another night of racing and another win for the Mi5, somehow the car just keeps getting better and stays very consistent through out the run. My top 20 lap time is generally within .25 seconds of my 20 lap average in a 29 lap race. The original R9-R body was getting a bit beat up so I painted this today:
Schumacher painted across the top? Really unique look, superb!
Old 07-20-2013, 05:10 PM   #962
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by DavidNERODease View Post
https://docs.google.com/file/d/0B8Vp...p=docslist_api
Thanks to Howdy_beecha for this very good fix!
What has been the problem with the caster bolts?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-20-2013, 05:12 PM   #963
JayBee's Avatar
Another night of racing and another win for the Mi5, somehow the car just keeps getting better and stays very consistent through out the run. My fast lap time is generally within .25 seconds of my 20 lap average in a 29 lap race.
Nice body. What class do you run?
Old 07-20-2013, 06:52 PM   #964
Trader Rating: 38 (100%+)
The local track runs 17.5 non-boost only. I am still trying to figure out what I will run at IIC, 17.5 and 13.5 or 13.5 and mod.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 07-20-2013, 07:04 PM   #965
The stock kingpins are only holding on by about 2-1/2 threads once you get past the chamfer.
Howdy_beecha is offline   Reply With Quote
Old 07-20-2013, 07:19 PM   #966
Robert G's Avatar
if anyone is looking for a MI5 im selling mine 325.00 shipped only ran twice
im sticking with off road.
pm me if interested thanks
Sold
Robert G is offline   Reply With Quote
Old 07-20-2013, 08:05 PM   #967
Potoczak's Avatar
Trader Rating: 107 (100%+)
Is there any other options for the outter hing pins? Not to thrilled about using e-clips to secure the pins.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-20-2013, 08:19 PM   #968
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
ygpm
OVA is offline   Reply With Quote
Old 07-20-2013, 08:38 PM   #969
haywood's Avatar
Trader Rating: 48 (100%+)
You can drill a hole and use a 3mm grub screw.
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 07-20-2013, 09:06 PM   #970
It still took a massive hit for me to finally pull out the stock kingpin bolt.
DavidNERODease is offline   Reply With Quote
Old 07-21-2013, 06:08 AM   #971
NITROmmm's Avatar
Post
Thanks, nice pics. Will give this a go, have pulled a couple out with very light contact. Running on a small tight indoor asphalt track, just trying to free the rear a bit to let it rotate better.
He who laughs last, thinks slowest!
RC HOBBYZONE
NITROmmm is offline   Reply With Quote
Old 07-21-2013, 12:11 PM   #972
Just started assemble my Mi5 kit, and I have a quick question.
Shall the wishbones fall down easily when screw to tha chassie ? It seems like 2 of the wishbones, are more free than the other two, and I have only lightly tighten the M3 screw with the spanner.
Shock Tower is offline   Reply With Quote
Old 07-21-2013, 12:40 PM   #973
mutley001's Avatar
It shouldn't matter how tight the m3 screws are done up the wishbones should pivot freely on the balls so the fall freely under their own weight.
If they don't then give em a wiggle a few times up and down to try to loosen them up - a tiny drop of bearing oil can help too
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-21-2013, 03:34 PM   #974
What link plates are people running most run 4 link plates but when i try car just bogs down???
Unless i run 3 link plates ???
Running 450 oil in shocks
2mm shim on inner plate 3 groove
1mm in outer 1 notch plate
1.5 front plate under ball 3 groove
.5 lower roll centre all over
3 degree toe
5 front 4 rear droop
Blue front roll bar
Red rear bar
Sorex 32 ry only ones allowed
Any ideas ??
Quietman is offline   Reply With Quote
Old 07-22-2013, 12:59 AM   #975
Got to have another run yesterday. Just a bit of practice with the Mi5. After 6 years out of touring cars its a pretty damned easy car to drive. Im running 13.5 so all new to me. I felt like it was very fast and very easy to drive. I have bought parts needed to switch to Hofer setup and look forward to that.
Ozasis is offline   Reply With Quote
