Old 07-17-2013, 07:35 PM   #946
Potoczak's Avatar
Trader Rating: 107 (100%+)
Got it thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-18-2013, 09:17 PM   #947
Potoczak's Avatar
What's a good starting setup for this car on medium to high bite asphalt? Technical layout. Thanks
Pete Potoczak
Old 07-19-2013, 03:17 AM   #948
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Try Martin Hofer's setup here
I use it on low to medium asphalt tracks with good results.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-19-2013, 08:39 AM   #949
Default Caster Block Bolt Fix
https://docs.google.com/file/d/0B8Vp...p=docslist_api
Thanks to Howdy_beecha for this very good fix!
DavidNERODease is offline   Reply With Quote
Old 07-19-2013, 08:42 AM   #950
Just file the burr off the end of these bolts and perfect.
Old 07-19-2013, 08:47 AM   #951
Now if I can just make these public from freak'n phone... The Android app won't let me share the link - will fix later via a real computer.
Old 07-19-2013, 09:32 AM   #952
John.C's Avatar
Trader Rating: 36 (100%+)
Thanks to Howdabeecha for this very good fix!
Thanks for sharing. I'm assuming the extra length/thread of the screw goes to strengthen this area.
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 07-19-2013, 09:49 AM   #953
Yes, these bolts fit perfectly - on the bearings and depth wise in the caster block. You can tighten them a little more without worry of stripping out threads and overall play is reduced over the stock parts. Wheel clearance is better, appearance is better, assembly is easier, durability is significantly improved and the cost is practically free. Just be sure to take 5 seconds to hand file the end of the bolts just to clean them up so their is no chance of drive shaft contact. Thanks again to http://www.rctech.net/forum/members/...cha-88554.html
Old 07-19-2013, 09:57 AM   #954
No problem!
Howdy_beecha is offline   Reply With Quote
Old 07-19-2013, 12:07 PM   #955
Everyone should be able to access the images now.
https://docs.google.com/file/d/0B8Vp...it?usp=sharing
Old 07-19-2013, 02:34 PM   #956
thank you for the pics.....
beaven is offline   Reply With Quote
Old 07-19-2013, 02:42 PM   #957
mutley001's Avatar
Any updates on the use of Helicoils to.solve the stripping of threads in the front hubs?
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-19-2013, 03:16 PM   #958
I have not had one strip out since using the longer screw. The issue seems fixed and for allot less money then the heli-coils I ordered (80.00 kit).
Old 07-19-2013, 05:44 PM   #959
Potoczak's Avatar
Does anyone know if Schumacher is going to do videos with Chris grainger and the mi5 like they did with the 4??
Pete Potoczak
Old 07-19-2013, 11:46 PM   #960
Trader Rating: 38 (100%+)
Another night of racing and another win for the Mi5, somehow the car just keeps getting better and stays very consistent through out the run. My fast lap time is generally within .25 seconds of my 20 lap average in a 29 lap race. The original R9-R body was getting a bit beat up so I painted this today:
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
