Old 07-14-2013, 11:04 PM   #931
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Cpt.America View Post
I think he was planning on running just F1. I haven't heard of any interest in him running a new TC.
He sold his F1 to Cookie . Cookie ran ritchie F1 last sat at the Northwest Asphalt Challenge ....
btw you did well at the Northwest Asphalt Challenge ..good job
OVA is offline   Reply With Quote
Old 07-15-2013, 01:00 AM   #932
Well I was very impressed with rear motor position when I ran first week, then I converted to mid motor, first night went ok but loosing grip on hard power out of corners, changed a few things this week (changed the rear springs to red, 1.5 camber all round and front shocks down one) the car was totally different, massive amounts of corner speed, took full throttle out of corners great, the car this week was much better than the driver. I am totally sold on the mi5 now in mid after seeing how small setup changes can really alter the lap times, waiting for my shortys to arrive then we will try play with weight distribution see how that effects it.
I had a few knocks when trying to run straight though a chicane only thing I damaged was the kit servo horn which stripped. what are you guys running metal? or servo saver?
nmsraider is offline   Reply With Quote
Old 07-15-2013, 01:13 AM   #933
JayBee's Avatar
Trader Rating: 31 (100%+)
Yes. KO Propo PDS-2413 ICS
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-15-2013, 01:55 AM   #934
Hi all,
Im currently running a BD7 in Modified (4.5T with boost).
But spool outdrive and central pulley are not very good. They wear out quickly
Are they more durable on Mi5 ? Driveshaft are durable too ?
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 07-15-2013, 05:21 AM   #935
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Originally Posted by nicoo2k4 View Post
Hi all,
Wear has been very good so far on the Mi5 (running in the same class as you). Spool outdrives have replaceable "slider" inserts that are relatively low cost.
Alloy centre pulley should last a long time.
To be fair though, the car has only been out for 6 weeks, so it's kinda early days.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 07-15-2013, 10:00 AM   #936
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I run a Futaba bls451 or bls551, with no servo saver. Best servos iv ever owned.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-16-2013, 05:52 PM   #937
Trader Rating: 72 (100%+)
Do the PN SCHG884 DCJ CVD front axles offer any performance or handling benefit in the Mi5?
Wondering because:
--- On one hand in another car (TC6.1) DCJ's smoothed out the front wheel's chattery-drive at larger steering angles very nicely
--- On the other hand the Mi5 has so much steering that I don't need to turn the wheel so far as to induce "the shakes" while driving, even with the Mi5 on a stand and the front wheels at full lock the chatter is minor and, if the Mi5 doesn't really need DCJ's, that's 60 bucks saved.
Is anybody finding that DCJ's in the Mi5 really make any difference in lap times?
Your insights are welcome.
Bill S.
waswadener is offline   Reply With Quote
Old 07-16-2013, 06:00 PM   #938
mine is almost done,picked up some tires at bruckner hobbies today and my servo will be here tomorrow. this thing is almost too pretty to run. i put a chassis protector sheet on and am almost ready to try it out,hope i can find a nice new parking lot....
beaven is offline   Reply With Quote
Old 07-17-2013, 04:40 AM   #939
Potoczak's Avatar
Trader Rating: 107 (100%+)
Originally Posted by DirtyDog3375 View Post
So far so good...
Built up well. On track performance is a work in progress. (running mod on large outdoor asphalt tracks - low -med gip with mega bumps)
Started with Hofer starting setup....will report more soon.
  • No breakages (after some decent crashes)
  • Some play in front castor block (no more than other cars) - taken out with 0.1mm shim
  • Reshimmed diff and spool with 0.1mm each side instead of supplied shims
  • added purple bling parts
Where did you get the purple body post holders??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 07-17-2013, 04:44 AM   #940
i dont see the absolute need for double joint axles.. I've had them but changed back to the steel drive shafts. Spec-r shafts are just not as durable in my opinion and have alot of play comparing to other brands..
JanE is offline   Reply With Quote
Old 07-17-2013, 06:11 AM   #941
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
They are actual Schumacher parts (I got them locally from Action RC - local Schumacher distributor).
The frt body height adjusters are Roche (6mm body height adjusters) from Roche HK.
The rr body supports are RIDE are got them locally as well. (when I used to run another purple car!)
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-17-2013, 12:44 PM   #942
What numbers of tooth is supplied in the kit in 48P ?
Shock Tower is offline   Reply With Quote
Old 07-17-2013, 01:13 PM   #943
Potoczak's Avatar
You wouldnt happen to have the part number for the schumacher part? i searched their site and could not find anything..
Pete Potoczak
Old 07-17-2013, 01:24 PM   #944
85 tooth spur mate.
Old 07-17-2013, 02:46 PM   #945
1 x U3158 Purple frt body mount
1 x U3159 Purple rr body mount
