Like Tree11Likes
Old 07-04-2013, 01:29 AM   #841
Originally Posted by scott_g View Post
Part nums for option parts:
Not sure about current avail of 2.5 arms from Schue direct but we have had them in stock in Aus since the car was first released, still have a couple sets.
They have them in stock now, lets hope i receive them soon, cause its the last parts i need to get my car from great to awesome
JanE is offline   Reply With Quote
Old 07-04-2013, 03:10 AM   #842
DiscountRCStore's Avatar
U4311 - 3 dink link mount
U4295 - rear hub carrier arm set (2 pairs)
U4354 - 2.5 deg rear arm - left
U4358 - 2.5 deg rear arm - right
Just received shipment confirmation on the arms.. should be available to ship to you Tuesday morning for anyone needing them ( 8 sets available ) ..
*Also available*
U4356 - 2.0 Rear LH
U4360 - 2.0 Rear RH
90T, 96T, 116T 64dp spurs
..Phil
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 07-04-2013, 05:11 AM   #843
Am just about to make an order for a Mi5, but are there some spareparts that are recomended to order at the same time. Was there something about some screws which was intended to brake, and then nice to have in spares, og what about c hubs and so ?
The option parts like Hoffer setup I have in mind, it is only normal spares I am thinking about.
Thanks in advance, can't wait to get my Mi5
Shock Tower is offline   Reply With Quote
Old 07-04-2013, 05:42 AM   #844
The only things I've used in spares are:
U4236 M3x10 CSK Alloy screws (the breakable ones)
U4256 Front knuckles
U3131 Alloy spacers (You lose these when you break U4236)
U4270 King pin and spacers (Haven't lost/broke these but I could see loosing them if you damage U4256)
U3814 Slider Insert (these are just a good idea to keep on hand and keep in good shape)
I've broken nothing else after some really hard hits getting used to the Mi5's wicked fast steering. Very impressed.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 07-04-2013, 05:43 AM   #845
Consider:
U4257 - 4* micro caster blocks ( no actual C hub on this car )
U4270- King pin and spacer
U4256 - Front hub carriers
U4255- rear hub carriers
U4236- M3 x 10 mm alloy csk screws ( they can shear on heavy impact )
The others may offer some others things I may've missed..
Hope it helps ...
..Phil
Old 07-04-2013, 08:56 AM   #846
Trader Rating: 38 (100%+)
I'd go with what was stated above, the cars seem to be very durable and well put together. I couldn't decide which set of spares I needed so I did this:
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 07-04-2013, 09:20 AM   #847
Thumbs up
That's a way to cover it all,
Old 07-04-2013, 10:34 AM   #848
Yeah but if your primary pit mat fails, your done for the weekend, I don't see any spare
Old 07-04-2013, 12:43 PM   #849
For the picky builders out there (me)...
- build quality is near perfect
- everything is very free (a little too much play maybe but way better than too tight)
- drivetrain is perfect, ultra free and everything runs true including the wheel hexes - love the layshaft pulley and spur design
- shocks are awesome
- leading design in all areas
- very fast out of the box (I'm racing blinky stock on carpet)
- easiest car to tune and work on by far
DavidNERODease is offline   Reply With Quote
Old 07-04-2013, 12:44 PM   #850
Love the Schumacher designed rear diff - hope that Shumacher does the same for the front but the stock front spool is sick.
Old 07-04-2013, 12:48 PM   #851
Very close to getting a second for VTA and emergency spare parts back up... VBC and ARC are it's contenders for me.
Old 07-04-2013, 02:34 PM   #852
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah....that's the most perplexing thing about the build. Can't understand that amid the midst of designing the rear gd, how come one for the front couldn't be? Just weird; maybe they're under contract with SpecR or something. Truthfully I will be running a spool or reg. diff until then....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-04-2013, 03:02 PM   #853
We here have been fielding allot of emails on this topic of a proper front diff being that the rear is so nice. When we spoke with Mark at Schumacher last Tuesday, he indicated that there were no immediate plans to develop a front diff for the Mi5. Spec-R will be the only option for the front.. at least for now !
..Phil
Old 07-04-2013, 11:34 PM   #854
Juhuu, just placed m order for an Mi5, and with the Surgested upgrades and spares. Can't wait till I get my hands on it.. It is interesting to compare this to my current Yokomo BD5Wxi, which I think drives like a dream.
Old 07-05-2013, 06:49 AM   #855
VTA wheels fit without issue - nice!
