Like Tree12Likes
Old 07-03-2013, 11:15 AM   #826
Questions??
Can anyone confirm if the extra .3mm shims in the shocks compress the o-rings enough to stop the leeks altogether. Or if it is also worth changing o-rings, ie softer muchmore varients. Already using green slime. And yes the shocks are built correctly.
I HATE rebuilding shocks so often when i rarley need to change viscosity.
Thanks.
kartdemon is offline   Reply With Quote
Old 07-03-2013, 12:01 PM   #827
AdrianM's Avatar
Originally Posted by linkless View Post
Same here, everything but the 2.5 degree wishbones since I haven't found them available anywhere yet. We are low-medium grip so the change might not be needed. I am short the 3 dink camber plate in the front, other than that it's an exact match. I will be swapping to the Schumacher springs (whatever rate is close to the Yokomo pink/blue) this weekend and see how things go. Hopefully I will have time to build up by second Mi5 and start getting some MOD practice in for IIC.
I was chatting with Martin Hofer and learned something about the springs. The Schumacher Green 16lb springs included in the kit essentially are HPI Silvers. Same steel, diameter, number of coils, production process, frequency, etc. There are awesome on asphalt.
Yokomo Pinks and Yokomo Blues are also both 16lb (or really close in reality) springs but they arrive at that rate differently from the Schumacher Greens and even each other. I know there are some spring charts out there that say different but Martin is adamant that they are incorrect. These are the ideal springs for carpet.
Yok Pinks are 16lb/6.5 coils/1.5mm wire (Stiff because of the wire diameter)
Yok Blues are 16lb/5.75 coils/1.4mm wire (Stiff because of the fewer coils).
Both are the same rate but they get there differently. When you drive an Mi5 with Green springs on carpet the car feel "On" the track. With the Yok springs the Mi5 feels "In" the track. Its hard to describe but there is a big difference in feel and how the car looks getting around the track. You get more side bite but it is less likely to traction roll with the Yok Springs.
This is why just about everyone (AE, Tam, Yok, HB, etc) runs HPI Silvers on asphalt and Yok Pink and Blues on carpet.
Adrian Martinez
Old 07-03-2013, 12:02 PM   #828
Additional question regarding extra shims in the shocks, what is the dimension to use, outer and inner dia. ?
Shock Tower is offline   Reply With Quote
Old 07-03-2013, 12:04 PM   #829
AdrianM's Avatar
Thanks.
If you get a Tamiya or 3Racing 4mm shim kit you will get .1/.2/.3mm shims. Start with the .3mm's and if you need more add a .1mm
http://www.tqrcracing.com/shop/produ....asp?p_id=3217
Adrian Martinez
Old 07-03-2013, 12:05 PM   #830
went to pick up my mi5 today but it wasn't there,bummer, i am itching to start the build. ordered some battery tape today,always used velcro but have had issues with the battery slipping out in my tc6 so i am going to try the tape. do you run it under the brackets and over the battery, how many layers?
beaven is offline   Reply With Quote
Old 07-03-2013, 01:57 PM   #831
Trader Rating: 38 (100%+)
I run it over the battery and one layer has been plenty....except I haven't had any real crashes yet.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 07-03-2013, 02:55 PM   #832
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Interesting about the Schumi Greens
+ about the difference with Yokomo springs, totally different feel to others
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-03-2013, 03:28 PM   #833
does anyone know when the 2,5 rear arms will be in stock? They have been in back order since they were first up on the schumacher site.. I pre orderd them aswell with my local hobby shop when i orderd the kit, but he wont receive them either since they are not in stock. Has been nearly 2 months now..
JanE is offline   Reply With Quote
Old 07-03-2013, 03:59 PM   #834
been trying to find what size body this beauty takes,190 or 200mm maybe im looking in the wrong place,tried the schumacher website and didn't see it,but i've been known not to see stuff thats right in front of me(senior moments)...thanks
Old 07-03-2013, 04:12 PM   #835
It takes a 190mm body.
John Barr
Old 07-03-2013, 04:26 PM   #836
it takes a 190 mm body. I like the Mazda Speed 6 body, it makes the car easier to drive. If you like a car that feels like it is more on edge, try the LTC.
gdcopbdcop is offline   Reply With Quote
Old 07-03-2013, 04:28 PM   #837
I also went with the shorty battery pack, and a smaller servo, and a lite-weight body. My car went from 1540 grams down to 1265 grams. It is well balanced with the speed-o behind the battery pack.
Old 07-03-2013, 04:32 PM   #838
Thumbs up
After a full day of testing on carpet I learned a few valuable lessons.
1. Martin's Hofer's Base Setup is an extremely good place to start. Don't skimp, get the parts you need to duplicate it exactly. I did and it was worth it.
2. The Yok Springs are crucial on carpet. The kit green springs are not good on carpet. I wanted to test the Schumacher Blue and Whites but I ran out of time.
3. Battery position makes a huge difference. With my batt in the rear the car was unstable on med grip carpet. In the Mid position the car became very smooth. This will allow me to put some of the rotation I took out with other settings back in.
4. If you change a setting on the Mi5 you will get exactly what you expect to get.
This was all with Jaco Blue tires, the kit motor position and a Protoform lite LTC-R mounted centered on the front wheel wells and with the rear wing overhanging ~8mm. I could get the Mi5 to be mellow and smooth or edgy and aggressive with the LTC-R so this will become my new standard body for all surfaces.
My lap times by the end of the day were competitive middle of the A-Main times. I am certain there is more speed in the car as I feel I made it too safe to drive by the end of the day. This is OK as this was my goal. I wanted to make sure I could get it to drive like a Caddy through conventional setup changes. Now I can make it more aggressive again and know I can get any balance I want.
Racing next Wednesday and looking forward to it.
Great stuff Adrian!
Old 07-03-2013, 04:40 PM   #839
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Part nums for option parts:
U4311 - 3 dink link mount
U4295 - rear hub carrier arm set (2 pairs)
U4354 - 2.5 deg rear arm - left
U4358 - 2.5 deg rear arm - right
Not sure about current avail of 2.5 arms from Schue direct but we have had them in stock in Aus since the car was first released, still have a couple sets.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 07-03-2013, 06:49 PM   #840
haywood's Avatar
Trader Rating: 48 (100%+)
Thanks!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
