Like Tree21Likes
Old 04-17-2013, 11:27 AM   #61
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Wow amazing car!!
Love my mi4cxl and this should be even better!
Blitzrockey is offline   Reply With Quote
Old 04-17-2013, 11:33 AM   #62
Originally Posted by Tony Newland View Post
I think the only reason they dont have as big of presence over here is their team is based in the UK. They havent pursued american drivers for many years. But with this car, the K1 and SVR being more tailored to the US style tracks, hopefully that will change soon I dont see any reason why the car wouldnt work every bit as or better than whats out there now.
The offroad cars have gained a pretty good following this year. They work great, durable and higher quality than the most common brands and people are starting to notice that.
I agree Tony. I love my SVR. I am getting the new MI-5, and hope to have it in time to race it at the Reedy Race of Champions next month. Are you coming?
gdcopbdcop is offline   Reply With Quote
Old 04-17-2013, 11:34 AM   #63
Trader Rating: 38 (100%+)
I couldn't agree more with this. I have had two schumacher buggies, great quality and current SVR is the bomb. I have had several schey TC cars. Hands down, best quality out there at its pricepoint. I have always had great support here in the US so anyone worried about lack of scheys in US and support. DON"T WORRY........
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 04-17-2013, 11:36 AM   #64
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by Mi4cxl View Post
The more I look at this. The more it impresses me.
+1!!!
Schumacher never disappoints when it comes to design!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-17-2013, 11:57 AM   #65
I'm not sure what to think yet.
There's some things that look awesome:
- Weight distribution options (battery and servo position)
- Motor mount setup with mid-motor option
- Central servo mount
- Control arms
- Omission of C-Hub, with bearings on the bottom
- Easy belt tension adjustment
- New gear diff
- Shocks mounted below arm centerline (but honestly, they could have done that with plastic)
- Rotated servo, with plenty of room for electronics
There's some things I'm disappointed to see carried over from the Mi4:
- Camber link plates, especially now that they've added the swaybar mount so I can't use the Mi4 ones I already have. The camber link plates are a pain in the butt, and it's expensive to buy different options. And as if it wasn't bad enough before, now there's a swaybar hanging off it. It seems like the swaybars, at least in the rear, could have been mounted lower, incorporated into the thing that retains the diffs. That way, they could have at least carried forward the Mi4 camber link plate unchanged.
- Slider inserts on the outdrives. They're not bad, exactly, but I'm not sure they were an improvement from blades, and it's harder to see when something's not quite right in there.
- O-Ring-retained wheel hexes. I think they allow more wheel wobble than clamp-on ones, especially as they wear.
There's some things that are interesting, but bring trade-offs with them, that may or may not work out well:
- The new steering looks trick, but it also looks heavy, isn't mounted particularly low, and the vertical balls on the steering mean no ackerman adjustability
- Fine-grained arm roll center adjustment at the cost of wheelbase, track width, and rear toe adjustment. Hopefully there's still a millimeter or two of wiggle room at the rear outer hinge pin for wheelbase. Track width can be done with wheel spacers. But rear toe... I guess we'll have to see how expensive options for that are.
- Optional rear outer camber link plates for fine-grained tuning at the outer hub, but at the cost of requiring more parts ($$) to have tuning options available.
- It looks like there's an awful lot of weight up high on the shock towers, due to the camber link plates, swaybars, and top deck mounting. That may work against the CG gains of moving the shocks down.
- There's a lot of new screws in the suspension, working against the weight savings of carbon arms and elimination of the C-Hub. 2 on each knuckle/hub and 2 on each arm = 16. Steel screws add up fast.
I think I will also miss the motor clamp. It gave so much range of adjustment for both front-rear distribution by messing with gear sizes, as well as left-right distribution to balance different battery and electronics weights. The only drawback was blocking some cooling holes on some motors, but I think it made up for that by working as a heat sink.
And things I'm just flat out disappointed with:
- The purple is gone
- Where'd the purple go?
- 404 purple not found
- Flushed and went purpling
- Flying purple sweeper eater.
Overall, the car is undeniably Schumacher, and I can't wait to see how it does in the next ETS round.
-Mike
Old 04-17-2013, 11:57 AM   #66
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Originally Posted by AdrianM View Post
As Tony said there are no top level US drivers running Schu sedans.
That said from a geometry, weight distribution and adjustability standpoint there is nothing that would hold the Mi5 (or Mi4CXL and Mi4LP) back from being more than competitive on US tracks.
^ agree
It appears to have every adjustment ever thought of
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 04-17-2013, 11:59 AM   #67
Purple = 80s parachute pants, just make it go away!!!
Black is the new blonde
Old 04-17-2013, 12:01 PM   #68
patorz31's Avatar
They should get credit for not just making another TRF clone.. I love the fact Schumacher like to go their own way
patorz31 is offline   Reply With Quote
Old 04-17-2013, 12:05 PM   #69
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by The Teacher View Post
YR4Dude, guess you didn't see the Awesomatix car...
I've seen it. The car is unobtanum with an unobtanum price.
The Schmacher has distribution here in the U.S. and hopefully a more market sensible price. My LHS already tells me that he can get the kit or parts within two days once its available. Try that with Awesomatix.
YR4Dude is offline   Reply With Quote
Old 04-17-2013, 12:10 PM   #70
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
WOW!!
Well done everyone at Schumacher!!
I like the mid motor option that alone makes me want one.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-17-2013, 12:18 PM   #71
The part that keeps me from getting excited about the new car is the lack of support in the US. There will be a 99% chance of you being the only person with the car at the 'big' race and from my recent experiences, this certainly isn't a good thing. I'm hoping that Schumacher gets a SchumacherUSA going again (maybe through Tony's shop) and puts more drivers on the roster so that this isn't an issue. Until then, I will have to hold off on getting an Mi5. And yes, my signature states that I currently own a brand of TC that has about the same support. My next one will certainly be more mainstream.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 04-17-2013, 12:23 PM   #72
Autocratic's Avatar
Trader Rating: 26 (100%+)
Love the new car. Can't wait to see it in action. This just might be my next car.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 04-17-2013, 12:32 PM   #73
Wheelbase and rear toe adjustment were the first thing I thought of when I saw the pictures.
On the Schumacher website the wheelbase is stated absolute, so I'm guessing there is no adjustment available at the hub. I guess toe could be easily done with an option wishbone with the mounting holes moved slightly which would be trivial with CNC (could do the same with wheelbase tbh).
I'm certainly not bashing, it looks very nice and I can't wait to see it out on track at the weekend.
cyclonetog is offline   Reply With Quote
Old 04-17-2013, 12:34 PM   #74
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Word!
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 04-17-2013, 12:36 PM   #75
Rick Vessell's Avatar
Originally Posted by Kevin K View Post
WOW!!
If you get one, I'll get one.
Rick Vessell is offline   Reply With Quote
