Like Tree11Likes
Old 06-22-2013, 11:16 AM   #721
Originally Posted by Cpt.America View Post
All 4 Mi5 drivers around here have moved to gear diff's in the font, and we are running between 600,000 and 1,000,000 cst oil.
Whats the reasoning behind that? Are you doing it for more initial turn in? Just asking cause I've found the Mi5 to have great turn in on asphalt.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 06-22-2013, 11:28 AM   #722
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It depends on the nature of the surface/tracks you race on. I have found the car to lack initial turn-in (just a tiny bit), but really excel on the exits. The geardiff helped balance the "feel" between corner entrance and exit.
Also, (and primarily) our outdoor asphalt tracks aren't the smoothest... so the geardiff with a really really high weight oil, just seems to "soak up" some of the inconsistencies with a bumpier track as the two front wheels can spin/shift between one another, instead of being locked with a spool.. Car has more traction over-all, everywhere. The 600,000+ oil allowes the car to pull from the exits LIKE a spool...
The downside is, the car is heavier.
(EDIT: Also, this isn't something I have totally settled on... iv run the diff the last two weekends... and will likely run it tomorrow... but will go back to the spool to compare. Who knows where I will end up )
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-22-2013, 06:17 PM   #723
silvalis's Avatar
Trader Rating: 29 (100%+)
What body are most people running?
I'm toying with the idea of running the Ride liberty body for extra steering. I'm not entirely sure if this has more or less than the ltcr...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-22-2013, 07:01 PM   #724
AdrianM's Avatar
The factory schumacher gear diff fits and runs great in the front. All 4 Mi5 drivers around here have moved to gear diff's in the font, and we are running between 600,000 and 1,000,000 cst oil. The front belt shifts to the left a little bit since the pully is closer to centerline than the spool, so you might need to double check your belt tension, but that's it. Works great, zero issues, and you don't need to run the crappy spec-R. The Schui gear diff is worlds better.
The Mi5 rear diff will not work up front. You need to run the Spec R Mi4 gear diff in front of the Mi5.
Adrian Martinez
Old 06-22-2013, 09:02 PM   #725
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Can you post a photo of how much the belt is skewed? Running with the belt divider on the centre pulley or without?
Have you run modified with the mi5 gear diff up front, or only spec classes? Very interested in this experience.
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 06-22-2013, 11:43 PM   #726
Trader Rating: 38 (100%+)
I have been running the R9R on mine because I like the looks of it. It is performing very well but I do have an LTC-R to spray for it as well. I am looking into putting a gear diff up front as well, just haven't gotten around to it. With our low grip it eases the transition and helped my Serpent quite a bit. The Mi5 was already better and if it sees the same improvement will likely be unstoppable at the local level.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 06-23-2013, 02:53 AM   #727
scoyle's Avatar
Hi, I have done a bit of a build review of the Mi5 on my site and it would be great if you would check it out and give me any feedback (good and bad!)
The review; http://www.rcracingni.co.uk/?p=116211
It really was a great build and if the weather would sort itself out in the UK I may even get to race it!
Thanks,
Stephen
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 06-23-2013, 03:52 AM   #728
Thanks,
Stephen
Which fan mount are you using in those photos? That looks pretty slick.
Old 06-23-2013, 05:39 AM   #729
Thanks,
Stephen
Nice writeup Stephen!
The Mi5 really is a nice car. So easy to work on, and I am amazed by how it responds to setup changes.
I run mod on a low grip asphalt track, but its so much fun!
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 06-23-2013, 08:12 AM   #730
scoyle's Avatar
It was a mount I got from Reflex Racing when I was running a TC6.1 Worlds; http://www.reflexracing.net/RSD-2530...t-_p_1043.html
Stephen
Old 06-23-2013, 12:17 PM   #731
I'm guessing you probably know who Brett Sisley is, given both your past involvements with Schumacher. Has he told you it doesn't work? Because he's demonstrated that it works just fine even in modified. It just doesn't look perfect.
-Mike
Old 06-23-2013, 02:14 PM   #732
Super Moderator
No need to speculate and spread misinformation, just try it. Works 100% perfectly fine. No offense intended.
-Mike
Yep.. Sisley and I both run an additional gear diff up front and haven't experienced a single issue. I run one in 17.5, and Brett runs one with his 5.5. Sisley is a monster (knows his stuff), and he had to convince me that the slight angle of the front diff belt wouldn't be an issue... and so far, he is right. If we discover any problems later, we will report.
- RCSpecialties -
Old 06-23-2013, 03:00 PM   #733
Super Moderator
Here you go... no discernible issues in either mod or 17.5. (no additional belt ware noticeable either) And the diff is SO much better than the specR.
- RCSpecialties -
Old 06-23-2013, 06:16 PM   #734
silvalis's Avatar
Anyone running a shorty + esc behind shorty layout? I thinking about doing it, but rough measurements have L/R balance is good, F/R balance is good (rear bias) but corner weights are out by 30-40g FL & RR.
Total weight is 1342 (aus rules is 1380, unless im reading these rules wrong) so i can just pop a few weights around the chassis and get corner weights closer to even (but not quite)
Probably not worth worrying about?
Old 06-23-2013, 06:39 PM   #735
Steering knuckle issue update. I have pin pointed the issue. Still waiting for helicoils. However. The kit knuckles had a slight chamfer the spare parts we recieved have a much larger chamfer. Once the kit ones wore out the replacements only last one race day on our carpet track. The king pin only threads in the new parts 3 threads. Iam going to try longer screws as well as the.helicoil. I will be sending my findings to mark asap.
This car out performs everything else on our high bite carpet. I just need the knuckles to last. Also to note I am not hitting boards. These tend to fail mid sweeper or quick switch back.
Howdy_beecha is offline   Reply With Quote
