Old 06-10-2013, 02:52 PM   #631
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by AdrianM View Post
The Schumacher alloy screws are very good quality, just not very pretty. if you want pretty you will need to get color anodized screws.
I have used these and they are very good. The plain ones look just like the Schumacher screws, the anodized ones are nicer looking.
http://www.4chobbysupply.com/servlet...ric/Categories
The new Schumacher spring range is the same as the HPI spring range (size, steel alloy, winding, coil count, frequency, finish, etc...). Schu Green = HPI silver. You can go harder and softer from there.
Thanks!
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 06-10-2013, 07:37 PM   #632
Nice one DirtyDog. Where do you get those purple body posts holder parts?
Ozasis is offline   Reply With Quote
Old 06-11-2013, 05:14 AM   #633
heavy's Avatar
Trader Rating: 20 (100%+)
In stock at ActionRC
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 06-11-2013, 05:27 AM   #634
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hi Chris,
Glad to see you back mate. The purple body post holders I got from Heavy at Action RC. The purple body height adjusters are Roche (I got them direct from Roche HK - Max) and Ride rear body stiffeners from a HK shop.
Thanks,
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 06-11-2013, 12:46 PM   #635
The arms are designed to run into the bulkheads during side hits and stop before they move far enough to bend or break a screw.
As you said the fronts get glancing blows and the alloy screws function as a fuse to prevent chassis damage.
If someone's front screws are breaking easy chances are they are over tightening them and introducing stress cracks. Make them snug, they wont loosen and they will take a substantial hit before breaking.
Now that I have assembled the arms etc I see... very happy with the build so far. I did have to remove a very very small amount of material from the front arms because they were contacting the bulkheads. I was careful not to negate the brace effect agaisnt the bulkheads during a side hit.
DavidNERODease is offline   Reply With Quote
Old 06-11-2013, 11:18 PM   #636
Ill have to check out ActionRCs online shop then Thanks guys
Old 06-12-2013, 10:38 AM   #637
So far the steering rack is completely amazing, once it beds in it is really smooth and makes for some nice steering. One maintenance tip though: go in with a soft toothbrush and clean up the front and rear surface of the centre track rod (U4268) since they can accumulate junk if there is any kind of sticky debris. I do it now at the same time I check and clean the belt pulleys.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 06-12-2013, 11:12 AM   #638
AdrianM's Avatar
Maiden run for my Mi5 tonight!
Adrian Martinez
Old 06-12-2013, 11:26 AM   #639
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yep.. i wipe mine off every run.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-12-2013, 11:34 AM   #640
has anyone had their belt flip on them. on my first run, i was coming up to pass a guy...we rubbed wheels and i spun out. the car would move after that. i found that my front belt had flipped over and was binding the drivetrain. i thought it flipped rather easy. i have my belts set one notch below the kit setup because they felt really tight. they still feel pretty tight but should i run them tighter?
DOTMAN is offline   Reply With Quote
Old 06-12-2013, 11:48 AM   #641
AdrianM's Avatar
Thats odd. I have run my belts crazy loose in the past with no issues. My Mi5 has the belts at the kit settings now. I wanted them to bed in a little before deciding to loosen them.
Adrian Martinez
Old 06-12-2013, 12:03 PM   #642
yeah, i thought that was odd. oh well, i keep running as see if it happens again
Old 06-12-2013, 01:45 PM   #643
Hi im new to this site.. Ive recently just received my mi5 through the post and just wondered if anyone has experimented on a very tight small (with loads of harpins) "Sidcup" and a tight "wkrcc" carpet circuit at all?
And wondered which position they found both the motor and battery best at?
xSTxPhoeniXx is offline   Reply With Quote
Old 06-13-2013, 04:30 AM   #644
Fantastic kit. Very smooth build.
Tracktest hopefully during the weekend.
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 06-13-2013, 06:46 AM   #645
niznai's Avatar
Does anyone know where (apart from Schumacher themselves in the UK) can parts be ordered? Aussie dealers have no parts for the time being and Schumacher UK stuffed up big time (sent my parts to Spain) and I am over trying to deal with them. Anywhere in the US? Continental Europe?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
SEO by vBSEO 3.5.0
