Like Tree20Likes
Old 06-01-2013, 03:31 AM   #451
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Hebiki View Post
send yours down.. i'll make it faster. you know its good for at least A TENTH!
What's going on bro?! Its been a minute, lol! Its time for me to relax a little with the MMO's and do a bit of racing again. Got a little itch I need to scratch, LOL
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-01-2013, 05:52 AM   #452
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Cpt.America View Post
I've never heard of such a thing.
I have . it is call green...some club aren't allow to use tires suace ...
OVA is offline   Reply With Quote
Old 06-01-2013, 09:26 AM   #453
DesertRat's Avatar
Originally Posted by Kevin K View Post
I like the idea and it seems to be the trend so far lets see how it performs on the higher grip US tracks.
You must not have raced sedan with foam tires with the ultra light weight bodies. There are rules to prevent this from happening again. I believe that ROAR has a min. thickness rule maybe IFMAR too.
I never did get the chance to race sedan with foam much, but weren't those bodies really light to prevent trac-roll?
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 06-01-2013, 10:22 AM   #454
OVA
OVA's Avatar
yes and no..I think proto-form and Parma make form tires car bodies...
Old 06-01-2013, 10:27 AM   #455
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by gdcopbdcop View Post
and by the way, I was going full throttle with a boosted 17.5 and hit the wall...it was going very fast. (especially since I was using a speed passion reventon pro and NOT a tekin)!
You can't handle a Tekin boosted.....lol
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-01-2013, 10:30 AM   #456
STLNLST's Avatar
Originally Posted by AdrianM View Post
Clint, be careful making promises...you might end up wearing a little black dress again
You just ruined years of therapy....hahaha
Old 06-01-2013, 02:14 PM   #457
How much does a MI5 weigh race ready? In grams would be prefered. Please present also with what electronics installed.
Thanks in advanced
quasimodo is offline   Reply With Quote
Old 06-01-2013, 04:34 PM   #458
Trader Rating: 38 (100%+)
I just weighed mine at 1394 grams. East Coast lightweight Euro-R body (they are still a bit heavy), KO 411FH RX, Savox 1252 servo, Reventon R with Fan, Speed Passion V3.0 17.5 fixed endbell, SMC 5600mah 70c battery and Mylaps transponder. I believe it was 1381 with a protoform body last night.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 06-01-2013, 05:18 PM   #459
Now that I've had time to eat and rest....results from today.
The Mi5 managed to match the speed of the S411 and was much easier to drive. Our track is low grip carpet as stated above and we have been trying everything to get more traction. The fastest lap on this layout is a 12.5 and I was able to get both cars down to 12.6.
The car is mostly built to the kit setup right now with the following exceptions:
All shims removed from below arm pivots for lowest roll center possible.
Yokomo pink springs on the front (slightly softer than the kit)
Serpent White springs on the rear (slightly softer than the Yokomo Pink)
Camber 1.0 degrees on all corners (leaning the tires in creates a lot of build up)
Paragon Ground Effects soaked long enough to dry out
5.5mm ground clearance front and back
5mm droop on all corners
diff fluid and oil from the kit
Geared at 43t pinion/96t spur
As I stated, the car is very easy to drive with fairly aggressive steering but still really balanced. The rear is just as locked in as the front. I need to find a few more tenths but to do it you have to run close to the boards in a few spots and they are very unforgiving.
John Barr
Old 06-01-2013, 05:47 PM   #460
dflat57's Avatar
Got my kit today. Assembling it now. I reach up to step 9. It's talking about adding Thread Lock H1056. Did you guys get this with your kits?? I don't see that anywhere in my box. On the front it never stated that we need to supply our own. Did they just forget to include mine??
That nitro smell.....
dflat57 is offline   Reply With Quote
Old 06-01-2013, 05:51 PM   #461
dflat57's Avatar
Now my build has come to a total stop. I search and read thru this thread and not one mention of picking up my own thread lock. I would have surely gotten some today before the stores closed.....
Old 06-01-2013, 05:59 PM   #462
Xpress's Avatar
You can't be serious?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-01-2013, 06:04 PM   #463
dflat57's Avatar
My bad. They seem to be using T6-0112 instead of H1056. Unsure of why they didn't mention that.
Old 06-01-2013, 06:26 PM   #464
You can easily loose some weight with a low pro servo (1251) no fan on esc and a lightweight body (regular weight bodies are terrible). That's gotta be 15g right there. With my Xray in 17.5 I put my fan on the esc if I need to add weight, otherwise it's not needed in stock. And I'm sure you can get even lighter with some time and a lighter screw set
JOE SI is offline   Reply With Quote
Old 06-01-2013, 06:31 PM   #465
Has anyone else found arms rub the gearbox housings ever so slightly? My arms look like the amendment sheet.
Ozasis is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Joe Maxey, Worst87
