Like Tree11Likes
Old 05-28-2013, 11:50 AM   #361
Originally Posted by Cpt.America View Post
I just finished doing all the math around running a shorty pack and the ESC on the right side of the car last night, and the math just doesn't pan out. (at least with the weight of my electronics) I figured I would have to add ~60 grams of weight to make minimum weight running a shorty. And while that does give you the opportunity to get to dead minimum weight, and at the appropriate corners, I would much rather have 2500 more mah, and be 40 grams over.
(100 gram difference between full and shorty. 60 under with shorty, 40 over with full)
It has always been my school of thought to do your best to reach weight using higher mah, than stick-on-weights. The voltage drop advantage of using a higher mah better will be beneficial in the later minutes of a race, in a spec class. YMMV
-CPT
I find the car more balanced and faster in the corners
And u can weight up the corners better
I started with 5000 25c lipo's (bk in 2009) and was just as fast as the
Boys using 5400 40-50c , so battery size isn't everything and these are
4600 80c so I am only loosing 400 and I only pull 1300-1600 out of my lipo's
an 2700 if I ran 13.5t boosted so they are fine for 17.5-13.5t if ur running mod motors then I would run full fat lipo's
I would like to add I was running 6000 70c lipo's before and found these are just as good but 100g lighter so I have lowered my lap times by taking weight away
Car corners better
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 05-28-2013, 12:35 PM   #362
AdrianM's Avatar
Originally Posted by machocave View Post
Thanks for the info
I got the internal ratio incorrect. I had suggested a 66t 48dp spur for 17.5 blinky but a 70T would be better.
Every car has a min/max total tooth count. For the Mi5 the Min in 48dp that is 100 total teeth or 66 spur + 34 pinion = 100. That gives you a 3.49 final drive ( (66/34) x 1.8 = 3.49 ) which is too tall for small tracks.
You want to be in the 4.0 to 3.6 range for a small track in 17.5 Blinky. That is a 70T spur with 43-48t pinions.
Adrian Martinez
Old 05-28-2013, 12:52 PM   #363
Hi I am going to run about 3.21-3.15 at aldershot track which is a 70t spur biggest pinion in the manual says for a 70t spur is a 39 pinion giving u 3.21 but I bet u could run a 40t pinion to give u a 3.15
all or nothing
Old 05-28-2013, 01:02 PM   #364
AdrianM's Avatar
The 4.0-3.6 FDR recommendation was for a 25mx12m (80'x40') indoor carpet track.
Adrian Martinez
Old 05-28-2013, 01:05 PM   #365
machocave's Avatar
Thanks for the helpful update I can't wait to start building My kit should be arriving sometime today
MachoCave.TV
Because Everything Matters!
https://www.facebook.com/machocave
machocave is offline   Reply With Quote
Old 05-28-2013, 02:47 PM   #366
If you want a fdr of 4-3.6 u want 70 t spur with pinion 31-35t not 43-48t
all or nothing
Old 05-28-2013, 03:35 PM   #367
That looks good ...whats your procedure ...just sanding and painting....what type of paint?
I just sanded the chassis edges with dermal then used CA glue (only on chassis) wet and dried the CA with 800 paper, paint is Ford Polar pearl white with a hardener in, thinners to first light coat, again 800 paper then final thicker coat using small ass brush. essential tools include beer, and lots of it to steady your hand, cloth and blade to remove paint when too much beer has been consumed. Then when paint is fully dry 1500 to remove any imperfections 2000 to finish.
That looks striking Scott but what's with the purple wheel hexes. Surly they should be black or in your case white.
Yeah gonna have to get some bits sorted white turn buckles, that can be your mission Paul, find me some.
It looks like something out of Tron, the movie... does it glow in the dark?
Had to look that up never heard of it before, Kind of wish I had picked another colour now as white hop up bit are hard to come by.
nmsraider is offline   Reply With Quote
Old 05-28-2013, 04:50 PM   #368
EDWARD2003's Avatar
Default Just a little tidbit of information
For those who are running 17.5's or 13.5's on shorter tracks. If you want to achieve maximum rip out down the straights, infield and corners, adjust your FDR as discussed by Adrian M, and also adjust your radio settings with a more positive curve band. If you haven't done this already, you will see a huge difference in motor performance. Trust me .
I really wish I could get my hands on one of these chassis'.
EDWARD2003 is offline   Reply With Quote
Old 05-28-2013, 05:00 PM   #369
theatriks's Avatar
What settings on the radio are you referring too ?
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 05-28-2013, 05:18 PM   #370
EDWARD2003's Avatar
Throttle curve. Your stock radio settings will have a linear throttle curve which should be (0). You want a more positive curve set it to ( +40 or +50). Check your manual and get familiar with it
Old 05-28-2013, 08:12 PM   #371
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Changing your throttle curve doesn't affect your motor's performance. It only changes the relative throttle position in relation to trigger position.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-28-2013, 08:22 PM   #372
AdrianM's Avatar
Sorry, I think I read the 43-48 off the 64dp chart
Adrian Martinez
Old 05-28-2013, 09:09 PM   #373
Originally Posted by gdcopbdcop View Post
hey racer, I am also running the 17.5 non-boosted class. Did you use Martin Hofers setup, or did you run something different. would you mind sharing your setup please?
Thank you,
Rich
As per build in the manual with the following changes....
3 groove camber link plates front and rear
2 degree camber front and rear
Shock oil 35wt front 25wt rear
Gear diff 100wt shock oil
Double jointed front drive shafts
Sorex 32 control tyres
Mazda speed 6 shell
Stafford is a low grip track that does wear tyres quickly, hope that gives you a few things to try.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 05-28-2013, 09:17 PM   #374
Mazda speed 6 shell
thank you, I will give that a try
gdcopbdcop is offline   Reply With Quote
Old 05-28-2013, 10:10 PM   #375
cyba888's Avatar
Any T4 owners also have the mi5?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
