Old 05-28-2013, 03:51 AM   #346
dflat57's Avatar
I have done my research for a few days, read over this thread and decided to purchase this kit. The purpose is I want to go racing on my local track. I went out there recently with my Tamiya TA-06 and it was SO out of place. I want to keep up with the nitro guys. What motor would be suitable??
I've driven RCs around the streets for a while now, but this is something totally different. I know the kit is about $450, after buying that I should have a budget of around $600 for motor, ESC, servo and receiver.
Suggestions on servos would be great too.
I have the Futaba 3PL 2.4GHz FHSS Radio System. Is that good enough??
dflat57 is offline   Reply With Quote
Old 05-28-2013, 04:24 AM   #347
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Hello everyone.
I see you are all busy building your cars.
So here's another update of my blog. Trying to keep updating it more regularly.
You will also find the setupsheet from ETS Rd.4 in the Netherlands there.
CLICK ME
Martin
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 05-28-2013, 08:05 AM   #348
machocave's Avatar
Originally Posted by weekendracer_uk View Post
I have to agree the car is very easy to drive straight out of the box, as said before at yesterday's Schumacher BTCC Stafford meeting the mod and 13.5 boosted classes where won by Mi5's while in the 17.5 blinky class I took 2nd overall after finishing the build of my car at the track just in time for qualifying.
That's awesome news
MachoCave.TV
Because Everything Matters!
https://www.facebook.com/machocave
machocave is offline   Reply With Quote
Old 05-28-2013, 08:14 AM   #349
machocave's Avatar
Originally Posted by Martin Hofer View Post
Hello everyone.
CLICK ME
Martin
Hi Martin! You have an awesome blog and thanks for sharing your setup sheet! It's super helpful
MachoCave.TV
Old 05-28-2013, 08:16 AM   #350
machocave's Avatar
Originally Posted by nmsraider View Post
Or Lack of chatter video ---^
Got mine all built ready for electrics and setup. All went very smooth, hardest part out of the whole build was anti role bars.
Wow! Your Mi5 looks totally awesome!
MachoCave.TV
Old 05-28-2013, 08:17 AM   #351
machocave's Avatar
Originally Posted by DIALED View Post
Got it the Mi5 up and running yesterday. Car makes a ton of grip. Steering response is insane. Braking is uber consistent. Diff and shocks are dialed. Very pleased
Wow! Your Mi5 looks totally dialed!
MachoCave.TV
Old 05-28-2013, 08:20 AM   #352
machocave's Avatar
Originally Posted by jmoneym View Post
Putting some laps in Tuesday if my 64p spurs comes in. Going to start with 96/43
Wow! The electronics look awesome I'd bet your Mi5 is super fast
MachoCave.TV
Old 05-28-2013, 10:03 AM   #353
theatriks's Avatar
That looks good ...whats your procedure ...just sanding and painting....what type of paint?
Mod Mod Mod...I love Mod.....and scotch!
theatriks is offline   Reply With Quote
Old 05-28-2013, 10:09 AM   #354
AdrianM's Avatar
Are you a Tron fan?
Adrian Martinez
Old 05-28-2013, 11:06 AM   #355
hey racer, I am also running the 17.5 non-boosted class. Did you use Martin Hofers setup, or did you run something different. would you mind sharing your setup please?
Thank you,
Rich
gdcopbdcop is offline   Reply With Quote
Old 05-28-2013, 11:11 AM   #356
how do u do the droop ?
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 05-28-2013, 11:15 AM   #357
this is my 17.5t blinky car , need to add weight only at 1328g
all or nothing
Old 05-28-2013, 11:30 AM   #358
Talking
That looks striking Scott but what's with the purple wheel hexes. Surly they should be black or in your case white.
big paul is offline   Reply With Quote
Old 05-28-2013, 11:48 AM   #359
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I just finished doing all the math around running a shorty pack and the ESC on the right side of the car last night, and the math just doesn't pan out. (at least with the weight of my electronics) I figured I would have to add ~60 grams of weight to make minimum weight running a shorty. And while that does give you the opportunity to get to dead minimum weight, and at the appropriate corners, I would much rather have 2500 more mah, and be 40 grams over.
(100 gram difference between full and shorty. 60 under with shorty, 40 over with full)
It has always been my school of thought to do your best to reach weight using higher mah, than stick-on-weights. The voltage drop advantage of using a higher mah better will be beneficial in the later minutes of a race, in a spec class. YMMV
-CPT
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-28-2013, 12:04 PM   #360
It looks like something out of Tron, the movie... does it glow in the dark?
Looking good.
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
SEO by vBSEO 3.5.0
