Like Tree34Likes
Schumacher Mi5
Old 05-21-2013, 01:01 PM
  #271
Originally Posted by Racer X
Who makes the purple rear body mount supports? (see above photo)
3 racing. They don't fit Schui body posts. You'd have to get some HPI or similar posts.
-Mike
grippgoat is offline
Old 05-21-2013, 11:06 PM
  #272
josecarlo1129's Avatar
Good day to all!
Very nice and clean built here.
Sorry if I altered your image, sir. I would just like to ask what you call this aluminum piece that sits on top a clip. What does this do? TIA.
Cheers.
josecarlo1129 is offline
Old 05-22-2013, 02:31 AM
  #273
ali_g's Avatar
So far any issues with MI5 shocks?
ali_g is offline
Old 05-22-2013, 02:46 AM
  #274
Robert_K's Avatar
Originally Posted by josecarlo1129
Good day to all!
Cheers.
Body height adjust/retainer. This way you can change the height of the body with every mm, just turn it a bit. Instead of moving clip or work with O-rings.
Regards Robert
Robert_K is offline
Old 05-22-2013, 03:17 AM
  #275
Regards Robert
Thanks for the info, sir. Appreciate it very much. Cheers to you!
Old 05-22-2013, 04:14 AM
  #276
Martin Hofer's Avatar
Good day to all!
Cheers.
Hello.
First of all:
the kits are shipping, so happy building!
second:
it will be all black, according ot the pictures on the schumacher webpage. Since I like purple and as purple like all other colors is only nice when done properly, I stuck with purple and tried to get as much of it into my car as possible.
You could have it any other color you want, as all I did was to use colored screws, nuts and washers where possible
third:
I'm using regular body posts with ROCHE bodyheight adjusters front and 3-racing body supports in the rear. I found that the 3-racing item gives more stability in highspeed turns.
The 5th bodypost does roughly the same.
4th:
I've posted my basic / use it eveywhere setup up on my blog.
this is what I've used at the last ETS race too.
Unfortunately, unlike the competitors, I wasn't able to arrive before thursday lunch time, so I only had 1 (one!) dry practice run before qualification started.
Therefore the result was more than ok!
I was using the exact above mentioned setup and it was really very good.
5th:
the car is very very tough and can take a lot of beating. I'm sure you won't be disappointed.
I spent a lot of effort in crashtesting it ;P
so long.
Martin
Martin Hofer is offline
Old 05-22-2013, 04:38 AM
  #277
Trader Rating: 125 (100%+)
Originally Posted by Sootaj
Schumacher will start shippings today!
Hoferīs production car in ETS race.
Got a call from UK yest.
kwiksi is offline
Old 05-22-2013, 07:07 AM
  #278
MINE IS ON THE WAY ALSO!
gdcopbdcop is offline
Old 05-22-2013, 07:56 AM
  #279
STLNLST's Avatar
Trader Rating: 32 (100%+)
I haven't seen you or RacerX out for club races and your name isn't on the Reedy sign up's. You guys skipping it I take it
STLNLST is offline
Old 05-22-2013, 08:55 AM
  #280
been waiting for this car. so, it is up in the air. call me please..
Old 05-23-2013, 05:40 AM
  #281
I just came back from my LHS!
The kit just arrived this morning and am now
building it..
So far i noticed that the pivot balls for the arms and the droop screw
buckets are already glued to the chassis which i think is nice.
Although my chassis has some glue residue on the chassis, i couldn't do it better myself.
So far i'm very pleased.
I'll keep you posted...
miguelito75 is offline
Old 05-23-2013, 08:11 AM
  #282
rosko's Avatar
Which springs will fit hpi or xray t4? I wonder since the car has half a caster blk will they be half the price as the normal blks
rosko is offline
Old 05-23-2013, 09:40 AM
  #283
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by miguelito75
The kit just arrived this morning and am now building it..
oohhh!! jealous!
Cpt.America is offline
Old 05-23-2013, 09:42 AM
  #284
AdrianM's Avatar
Everything fits everything spring wise.
AdrianM is offline
Old 05-23-2013, 03:28 PM
  #285
Got mine today and its finished goes together very well
Quietman is offline
