Like Tree21Likes
Old 11-01-2016, 12:03 PM   #2746
dvsstrike's Avatar
Originally Posted by Infamous 1ER View Post
Does anybody know where I can get an aluminum chassis for the mi5? Thanks
if its for the 5 only a handfull were made. if it was for evo avid makes a good one.
Tim Linayao
Team Schumacher Usa Core-Rc Team Powers
dvsstrike is offline   Reply With Quote
Old 11-01-2016, 01:44 PM   #2747
patorz31's Avatar
And if you can get one of the handful made they demand a pretty penny, last one I was offered was more then an Mi5 kit was worth. Seems semi rare unobtainable pieces are very collectible.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 11-02-2016, 11:20 AM   #2748
Infamous 1ER's Avatar
Wow but thanks. Let's see if I can find one?
POWERED>>>>>> BY MAJS HOBBY SHOP IN HACKENSACK NJ!!!!!!
Infamous 1ER is offline   Reply With Quote
Old 11-02-2016, 11:24 AM   #2749
qcrc's Avatar
Check with some of the smaller/ custom aftermarket companies. I know there was a place that will make one but I can't remember who it is right now.
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 11-02-2016, 03:25 PM   #2750
Originally Posted by Diggy View Post
Can you post up your setup...? If you do not have it in pictorial form can you answer the following to assist;
Mi5 Evo
Alu plate
Spool front
Green springs front and rear.
Rear diff oil - Probably stock setup
Rear dampers are inclined all the way.
Camber links are at the outermost hole. (shortest) Probably stock setup
Arms looks like triangles.. Probably stock setup
I have the latest generation steering rack. Lets call it the traditional one.
MatsNorway is offline   Reply With Quote
Old 11-02-2016, 04:50 PM   #2751
chiefj48's Avatar
I have a brand new Mi5 in the sealed box for sale if anyone is interested please PM me
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 11-02-2016, 10:27 PM   #2752
Originally Posted by MatsNorway View Post
Mi5 Evo
Alu plate
Spool front
I've attached a copy of my current setup for the Mi5 Evo...it doesn't actually stray too far from the kit carpet setup. I added the 1mm shims behind the front wheels to help combat traction rolling but you could remove them and gain a bit more steering, especially going into corners. I'd also recommend the 2.5 degree rear arms unless you are running on a truly low-grip surface. 3 degrees will really lock in the rear of the car and not allow it to rotate, especially coming out of corners on-power.
Let me know if you need any clarification on anything!
Cheers!
Mike
Hyper_Mike is offline   Reply With Quote
Old 11-04-2016, 04:26 PM   #2753
Do you mean the shim on the chassie for the camber link at the front? less camber gain?
Old 11-05-2016, 12:31 AM   #2754
Diggy's Avatar
They are 1mm shims that go between the wheel hex and the wheel..
http://www.racing-cars.com/pp/Produc...ist/U4321.html
You will see them highlighted on the setup sheet to the left of the front shock tower "box" and are called wheel washers.. it shows the Hex and front hub in the diagram.
HTH.
M
Mod TC - Schumacher Mi6
Formula 1 - Xray X1
Pro12 - Schumacher Eclipse
Schumacher | Sanwa | Fantom | IP |
Diggy is offline   Reply With Quote
Old 11-09-2016, 04:09 PM   #2755
besides the schumacher cvd, what other brand can i use for the mi5 that would fit?
thanks
Old 11-27-2016, 09:51 AM   #2756
patorz31's Avatar
Anyone have a setup for the Mi5evo for USGT on black carpet?
Old 12-02-2016, 01:49 PM   #2757
Aja Archibald's Avatar
Yes, I had a few outing with it at 360V2.
I write it up for you tonight.
Team Schumacher USA www.racing-cars.com// Team Sweep Racing Tires USA www.sweepracingusa.com// Hobbywing UK // Atomic USA www.rcatomic.com // SkyRocket Racing www.skyrocketracing.com // UPGRADE RC Products www.upgrade-Rc.com // Champion Hobby // Maj's Hobby // Crispy Critters // AbsoluteHobbyz.com // LAB Motors // Clockwork Racing Engines
Aja Archibald is offline   Reply With Quote
Old 12-02-2016, 11:02 PM   #2758
patorz31's Avatar
Thanks i cant wait till you post it up.
Old 12-19-2016, 03:45 PM   #2759
PM Sent.
Old 12-19-2016, 07:27 PM   #2760
patorz31's Avatar
Originally Posted by Aja Archibald View Post
PM Sent.
Your PM didn't go through.
