Like Tree21Likes
Old 04-10-2016, 04:26 PM   #2641
Trader Rating: 25 (100%+)
Originally Posted by DiscountRCStore View Post
.. after looking over the parts list .. it again appears to be largely a new platform.. Looks like some of the smaller bits ( F/R Hubs, Caster Blocks, Driveshafts ) will transfer over from the EVO but nearly all else is new.. Diff, spool, arms, bulkheads, bumper molds, belts, top decks, chassis, etc are all new... It'll likely be easier and less expensive to purchase new than try to convert .. IMHO
...p
Oh, ok. I just bought a new Mi5 Evo so I guess I'll have to stick with it for now. The MI6 looks spectacular. Schumacher products are always great.
madness is offline   Reply With Quote
Old 04-12-2016, 04:58 AM   #2642
roger999's Avatar
Just ordered mi5evo and wondering what rear toe in arms come as standard and what springs are in the kit?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 04-12-2016, 06:53 AM   #2643
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
The 3 degree arms and green springs are the kit standards.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 04-12-2016, 10:44 AM   #2644
roger999's Avatar
Old 04-14-2016, 06:37 AM   #2645
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
My diff is leaking only from the left outdrive. What is the best way to build this thing to prevent leaks? Are the red schumacher seals better?
tonyv2382 is offline   Reply With Quote
Old 04-14-2016, 07:14 AM   #2646
DiscountRCStore's Avatar
The red seals (U4712) have worked better in our experience and are Schumacher's solution for that issue. When installing, we usually use a bit of the black moly grease or diff grease with the ring(s) to help better seal and minimize the wearing of the seal against the out drive itself.. It also helps when reassembling to put a thin film of grease on both sides of the shim(s) that go underneath the bevel gears for the out drives.. this should help to virtually eliminate any leaking from the the out drives themselves .. Hope it helps ..!
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 04-14-2016, 08:09 AM   #2647
tonyv2382's Avatar
..p
Thank you. I will try it today during practice
Old 04-14-2016, 08:22 AM   #2648
I've always followed the instructions from
Schumacher Mi4
They are for the Spec R diff, but the green slime seems to stop all leaks. I use it on the shocks as well now.
tonybod is offline   Reply With Quote
Old 04-14-2016, 08:35 AM   #2649
tonyv2382's Avatar
I personally dont like green slime on shocks or anything else. Makes the oils mirky. I dont think it seals all that well either. A lesson I learned from Kyosho is that the Orings are the be all end all of a well sealed component. If the Orings are not up to par your stuff will always leak. Grease itself cant hold back a leak.
Old 04-14-2016, 03:06 PM   #2650
tonyv2382's Avatar
Your method worked great thanks again. Do They make DCJ for the mi5 evo?
Old 04-14-2016, 03:47 PM   #2651
Great news ! Glad to hear that it worked for you ..
The part number for the DCJ's are G920 and can be found here
..p
Old 04-14-2016, 03:59 PM   #2652
tonyv2382's Avatar
..p
The link didn't work. Thanks so much!
Old 04-14-2016, 05:30 PM   #2653
If I'm just getting into on-road do you folks think buying a new Mi5 Evo kit at $260 is a deal or is it just throwing money down the drain/buy latest and greatest Mi6?
What will parts support look like for th Mi5 in 6 months?
Jsapata is offline   Reply With Quote
Old 04-14-2016, 09:06 PM   #2654
It's difficult to say for certain .. The EVO is still a very competitive car.. especially at the club level. Most of us (shops) will likely sell down their excess inventory and keep the basic consumables on hand ( arms, hubs, carbon bits etc ) however as the line develops and moves on, so must we as that is where the demand is going; we can and do special order for guys all the time as long as the bits are available at Schumacher.. hope it helps
..p
Old 04-15-2016, 09:17 AM   #2655
tonyv2382's Avatar
I Ran the car repeatedly for practice last night and I can definitely say it is very durable, parts quality is amazing, it is VERY consistent to drive. And has a ton of tuning options. If youre running on carpet you will need the DCJs up front. So far though very impressed and ive only been out with it once. I think for the price theres nothing better you can buy right now. I will also say this, newer isnt always better. There are guys at my track that run old Xrays that clean up. So its all about your driving and developing your skill.
I used to run for Schumacher in offroad, all I can say is when I built this kit I forgot how well thought out things actually were with their cars. What car can you buy that offers a mid motor conversion, shocks you can build any which way you want, ease of maintenance, especially removing the spur gear, and diff. Super Low CG, 3 different top decks to run, aluminum chassis, and just easily adjustable. This car is awesome IMO. Id like an MI6 also but ill wait till the bugs are worked out and get it on christmas lol.
