Like Tree21Likes
Old 01-01-2016, 08:30 AM   #2611
Originally Posted by mufdvr1 View Post
I have a mi5evo with blinky mount running vta front diff at 500000cst I am still about a half second slower than the top cars even with those drivers driving it I am at a loss for what else to try. 59t and have tried everything up down with pinions different motor/esc and still the same. any ideas!!!!!!!!!!!!!!
Are you using the chassis braces on the front and rear? The evo gets so much grip.
Especially in vta you need to free it up, the added grip slows you down.
I would try stiffer springs, thicker shock oil, if the grip is really high I would try thicker oil in the rear diff.
gdcopbdcop is offline   Reply With Quote
Old 01-08-2016, 09:40 PM   #2612
RoyB's Avatar
Trader Rating: 16 (100%+)
Anyone stock the Eccentric Side B -Mi5 U4266 in the USA.
RoyB is offline   Reply With Quote
Old 01-09-2016, 06:11 AM   #2613
Speedtechhobbies.com
mufdvr1 is offline   Reply With Quote
Old 01-09-2016, 10:21 AM   #2614
RoyB's Avatar
thank you
Old 01-10-2016, 04:34 AM   #2615
Car Breaker's Avatar
Default Chance of new kit ?
It is 2016 now. We didn't have a new car last year, any chance we have an updated version thos year ?
Car Breaker is offline   Reply With Quote
Old 01-22-2016, 02:14 PM   #2616
RoyB's Avatar
I have 2 original Mi5s. Am running 1 in VTA and 1 in USGT. They are both are setup midmotor for carpet track. They both have 2mm chassis and running rear braces. The main difference is that the VTA has twin point steering.
The VTA runs well and can challenge the fast guys. The USGT pushes terribly under power. Does the twin point steering change the geometry enough to make this change? Or could it be the weight and power difference?
Old 02-18-2016, 04:33 AM   #2617
I'm preparing my Mi5Evo for the next round of the ToniSport Onroad Series on Carpet and have a question:
How do the thicker upper deck and the braces work together? Right now I have the 2.5mm upper deck and the 2mm alloy chassis. What would happen, if I opt for the braces and build back to the original 2mm upper deck?
Rincewind is offline   Reply With Quote
Old 02-20-2016, 01:04 PM   #2618
Default Welll...
I was asking the same thing both trackside and to a few shops that deal with Schumacher, and am led to believe that a replacement is imminent, but neither stores nor 'trackside' can say if it is another evolution, or a different car.
I get the impression that the only thing the team drivers do different to 'kit' appears to be: the steering, DCJ's, and tuning options such as springs or alloy chassis for indoors.
I have a soft spot for schumachers and am tempted to buy one coz they look very good on track
Loheswaran is offline   Reply With Quote
Old 03-13-2016, 08:23 AM   #2619
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Drove the mi5 evo for the first time last night on high grip carpet. I really like it. Set it up on the bench like my other cars and it was really consistent and actually very durable. No broken parts after a full day at the track. It does flex a lot so I may go to the aluminum chassis or play with some top decks and rill center adjustments. All in all I really like the car.
tonyv2382 is online now   Reply With Quote
Old 03-14-2016, 12:33 AM   #2620
Different car. Will go back to a conventional topdeck and wishbones.
Mi4cxl is offline   Reply With Quote
Old 03-14-2016, 08:13 AM   #2621
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
That's too bad. I like the design - and it works very well on my home track with medium grip asphalt.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 03-14-2016, 07:34 PM   #2622
The Teacher's Avatar
Trader Rating: 48 (100%+)
RoyB, play with your droop in the front to have less weight transfer to the rear under power. Should help with the push.
The Teacher is offline   Reply With Quote
Old 03-14-2016, 07:39 PM   #2623
RoyB's Avatar
Had way to much droop in the back, reduced it and the car got a lot better.
Old 03-17-2016, 01:47 PM   #2624
tonyv2382's Avatar
So do the red seals help the diff with leakage?
Old 03-21-2016, 11:00 AM   #2625
DiscountRCStore's Avatar
Correct .. they're Schumacher's solution for this issue .. recommended to use 2x large seals for the case itself ..
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
