Like Tree21Likes
Old 09-23-2015, 12:52 AM   #2581
Hello all
Im after some help please, im currently running a mi5 and was wanting to upgrade to a mi5evo, so is the body mounts in the same spot so i can use all my shells i have collected.?
Thanks guys
FPVguy is offline   Reply With Quote
Old 09-23-2015, 09:03 PM   #2582
Originally Posted by FPVguy View Post
Hello all
Thanks guys
I have one of each. The body posts are in different places, they do not match.
gdcopbdcop is offline   Reply With Quote
Old 09-23-2015, 11:25 PM   #2583
Bumma oh well,
are alot of the parts interchangeable between the two
Old 09-24-2015, 03:34 PM   #2584
Bumma oh well,
Front are the same back are not.
colinjackson is offline   Reply With Quote
Old 09-24-2015, 10:31 PM   #2585
Bumma oh well,
some of them are, most are not.
Old 10-12-2015, 01:06 PM   #2586
poochy's Avatar
What is the part # for the roche double joint hub carrier?
poochy is offline   Reply With Quote
Old 10-12-2015, 01:09 PM   #2587
pchroma24's Avatar
Trader Rating: 79 (100%+)
Part G920
http://www.discountrcstore.com/Schum...fts_p/g920.htm
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 10-12-2015, 01:43 PM   #2588
poochy's Avatar
Originally Posted by pchroma24 View Post
Thanks but i meant just for the black plastic pieces? Is that stock?
Old 10-12-2015, 02:08 PM   #2589
pchroma24's Avatar
Correct, the U4256 would be the correct hub .. The biggest difference in this setup is that it uses a 3mm bearing on the inside to better accommodate the slightly longer shaft ..
Old 10-13-2015, 08:31 AM   #2590
poochy's Avatar
Thanks..bought one from discountrc
Btw what would be the stock number for the new bearing needed?
Old 10-16-2015, 02:59 AM   #2591
DiscountRCStore's Avatar
Those are part U4726
http://www.discountrcstore.com/Schum..._3_p/u4726.htm
...p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 10-22-2015, 07:56 PM   #2592
Default 2016 mi5 evo updates
Are there going to be any revised parts or any thing new For the new year. Thanks
black juice is offline   Reply With Quote
Old 10-22-2015, 08:15 PM   #2593
pchroma24's Avatar
The Peripheral Dampeners were just released today; those should work well on asphalt.. I wouldn't expect anything too huge -probably just some upgraded bits .. The current car is pretty good already ..
Old 12-02-2015, 06:30 PM   #2594
Anyone tried the peripheral dampers? How's it compared to the stock ones?
N15M0 is offline   Reply With Quote
Old 12-06-2015, 06:55 AM   #2595
I have a shot at a good deal on an original MI5 (non Evo). I am looking for parts sources and don't see anyone having arms (wishbones) in stock, even Shumi site say's part number doesn't exist. Do the Evo arms and mounts work on a non Evo car?
Are most other consumable parts,Hub's, Knuckles, Arm mouldings the same?
Can a non Evo car be "updated" or not worth the cost?
GimpyGolden is offline   Reply With Quote
