Like Tree21Likes
Old 05-19-2015, 03:19 AM   #2566
The Teacher's Avatar
Trader Rating: 48 (100%+)
Thanks Phil, I will keep that in mind for this weekends testing.
The Teacher is offline   Reply With Quote
Old 06-19-2015, 01:26 PM   #2567
Does anybody know which rollbar clamps these are?
I've noticed a few of the top drivers are using them.
Mi4cxl is offline   Reply With Quote
Old 06-20-2015, 02:33 AM   #2568
They are mi5 roll bar clamps U4259
Schumacher Mi5evo-HW V3.1 - HW V10 13.5 dry car
Schumacher Mi5evo-HW Extreme stock-HW 13.5 wet car
Schumacher SSGT - HW V3.1 stock spec - HW V10 13.5
Racing-cars.com
MWarren is offline   Reply With Quote
Old 06-20-2015, 03:02 AM   #2569
And there was me looking at other manufacturers cars to see whos they were.
Cheers dude
Old 07-09-2015, 07:06 AM   #2570
I'm driving the Mi5Evo for the first season and I would like to install some upgrades. Can you guys help me with the following questions?
  • Are there black titanium or aluminium turnbuckles you can recommend?
  • What exactly has been optimized with the 2015 shock towers? The range left-right, height?
  • Do you have experiences with the aluminium rear axle? Especially durability and weight.
  • Which aluminium spring cups fit?
Rincewind
Rincewind is offline   Reply With Quote
Old 07-09-2015, 10:25 AM   #2571
DiscountRCStore's Avatar
    Only the purple we're aware of; U4579
    As close as we can tell, the holes are shifted towards the inside; seems to be in between the stock locations.. changes wheel rate slightly
    Yes .. durability is fine.. no issues in mod for us.. from memory, I believe they save ~8 grams total
    The best choice are the U3611 - you'd need 2 sets
Rincewind
.. hope it helps..!
..p
www.discountRCstore.com - Free shipping over $50 storewide
---> Like us on Facebook!
DiscountRCStore is offline   Reply With Quote
Old 07-09-2015, 10:35 AM   #2572
Rincewind
Core RC do silver titanium turnbuckles which look better than the purple ones
CR473-35mm
CR474-38mm
You'll need a 3mm turnbuckle wrench for them though.
Racing-cars.com
Old 07-09-2015, 10:43 AM   #2573
CR473-35mm
CR474-38mm
+1 - overlooked that .. doah..!
..p
Old 07-09-2015, 02:39 PM   #2574
Rincewind
Hi,
2015 shock mounts are inwards by less than half a hole, no real difference to be honest.
Alloy rear drive help with traction out of the corner and very durable.
U3611 Alloy Spring Seat - All shock types
Turnbuckles just standard for me.
Biggest option part to get are chassis braces, play around with these!!
adyb is offline   Reply With Quote
Old 07-14-2015, 04:16 PM   #2575
Thanks for all the replies I ordered a big pile of optional parts and will try around with them. Does anybody know which turnbuckles this guy is using?
(Cant Post links, google for "Schumacher Mi5 Evo Loaded")
Old 07-16-2015, 07:07 AM   #2576
dvsstrike's Avatar
just pm atomic for where he got them from
Tim Linayao
Team Schumacher Usa Core-Rc Team Powers
dvsstrike is offline   Reply With Quote
Old 08-03-2015, 01:45 PM   #2577
qcrc's Avatar
has anyone used the mid motor conversion? If so what were your thoughts on it?
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 08-03-2015, 02:15 PM   #2578
We used the MM on the original 5 with some success. It seemed to work best for us on tight, high bite, carpet where you didn't need so much weight transfer. The car felt very neutral overall and pretty easy to drive. We found it to favor a bit more of an easier/smooth driving style vs a more aggressive one if that makes any sense .. hope it helps..
...p
Old 08-18-2015, 07:21 AM   #2579
I managed to get some black aluminium turnbuckles for the Mi5Evo! The ones for the ARC R10 are 37mm and fit for suspension and steering (search for ARC R102815). About 7g in weight savings for 6 turnbuckles. I'm still searching for a longer one to replace the servo turnbuckle, but until now had no luck.
Anyone knows where I can get a aluminium turnbuckle in 52mm?
Another question: has anybody used the aluminium chassis from Avid? How does it compare to the original one from Schumacher?
Old 08-18-2015, 08:26 AM   #2580
rcshark's Avatar
Send a message via Yahoo to rcshark
Try Amain the yokamo has them in black.
rcshark is offline   Reply With Quote
