Old 01-20-2015, 10:40 AM   #2491
hydrakermit's Avatar
Originally Posted by Cole Trickle View Post
Thanks a lot, this is excatly the kind of info I was looking for :-)
I'm going to try the standard motor mount, and find out which works the best for me.
No problem
Would you like me to try and attached the set up sheet?
hydrakermit is offline   Reply With Quote
Old 02-10-2015, 01:41 PM   #2492
http://ets.redrc.net/2015/02/chassis...iott-harper-2/
so i wasnt lied too dual bell crank steering also look at the front spool out drives as do they look like old mi4 lp ones ? as the spool would fit . if so would like to know y they are used ?
cant wait to see what he does with the car outdoors
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 02-10-2015, 03:25 PM   #2493
rckenny2000's Avatar
Nice hopefully they will sell the dual crank steering setup soon as an option. I parked my Evo's because of the steering rack.
rckenny2000 is offline   Reply With Quote
Old 02-10-2015, 03:58 PM   #2494
the spool is new stainless steel. it doesn't have the plastic sliders. new stuff they are trying out. I also hope they have the new steering rack available...
gdcopbdcop is offline   Reply With Quote
Old 02-11-2015, 01:15 AM   #2495
malcnz's Avatar
whats wrong with the steering rack?
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 02-11-2015, 05:09 AM   #2496
HappyHippo's Avatar
MI1 V2 U3809
HappyHippo is offline   Reply With Quote
Old 02-11-2015, 02:31 PM   #2497
Just the out drive looks a lot like this one ? Not saying it's not a new item
http://www.racing-cars.com/pp/Old_Ca..._CF/U3141.html
all or nothing
Old 02-11-2015, 02:33 PM   #2498
What problem did u have, the dual bell crank from what I hear is mainly to save weight the mi5evo rack is better in performance
all or nothing
Old 02-12-2015, 05:49 AM   #2499
hoyt1967's Avatar
Trader Rating: 33 (100%+)
Question, on my Mi5 if I grab each side of the front outdrive I can rock the whole spool front to back. I pulled it apart and put in new bearings and a new spool. I see no other issues. So is this normal?? I'm sure with belt tension on it, it will not move. But it seems odd. My xray diff is mounted rock solid.
hoyt1967 is offline   Reply With Quote
Old 02-17-2015, 05:54 AM   #2500
emreyzc53's Avatar
--- SOMEONE CAN HELP ME PLS..
How many cm Mi5 rear diff.width.? in the picture below
emreyzc53 is offline   Reply With Quote
Old 02-18-2015, 11:27 AM   #2501
Originally Posted by HappyHippo View Post
MI1 V2 U3809
Do you use this for the Evo?
Old 02-18-2015, 11:28 AM   #2502
Use a pair of Veneers and measure it yourself maybe?
Old 02-18-2015, 07:08 PM   #2503
emreyzc53's Avatar
I haven't mi5 so I need rear diff. width .ıf someone have mi5 can measure it for me?
Old 02-19-2015, 12:37 PM   #2504
If it's for the cat or cougar kf then think they r the same try checking part numbers might be the same
Old 02-19-2015, 03:48 PM   #2505
emreyzc53's Avatar
Thank you but not same this part. Mi5 rear diff. difirent than others. Not riders who is my friend mi5. So ı can't find measure. I need mi5 diff. width.
SEO by vBSEO 3.5.0
