Like Tree20Likes
Old 11-16-2014, 01:16 PM   #2446
TryHard's Avatar
Originally Posted by MatsNorway View Post
Im thinking about getting the mi5evo. Is it ok on carpet? And schumacher is not about to drop a new one i should wait for?
No new car on the near horizon, although that's nots to say parts aren't being tested, just will fit the existing car.
Carpet pace seems good for sure, it's been on the podium at both of the uk's EWS rounds this year, with Chris and Matt.
Old 11-16-2014, 02:08 PM   #2447
Airwave's Avatar
I think they are working on something... I'm pretty sure official drivers weren't using standard kit cars at WC...
Airwave is offline   Reply With Quote
Old 11-16-2014, 04:19 PM   #2448
There Nornaly new one start or half way throught Brca nationals
But heard ( could be lies ) that they are looking at duel bell crank steering as a weight saver
And top drivers never have a out of box kit
tcboy1983 is offline   Reply With Quote
Old 11-17-2014, 01:48 AM   #2449
Damon's Avatar
http://rcracingtv.net/2014/10/get-yo...hris-grainger/
in this article there are some photos of Chis Grainger's Mi5 evo from WC, only new double-joint driveshafts, but the rest of the car is standard
generally a new car comes out in May-June
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 11-17-2014, 09:23 AM   #2450
Thanks. Silly of me to ask if it is good on carpet. I bet most cars would do for me. Ive had a Xray fk05 who was a great car to drive. Thick chassie plate and rubber tires. But for a year+ ago i bought a Sakura S Zero.. its so loose and flimsy in the hubs it makes me think: "this is pointless"
And now i want to replace it.. And just throw it in the thrash.
MatsNorway is offline   Reply With Quote
Old 11-17-2014, 02:44 PM   #2451
Jumped ship, Well after 2 years on the Schumacher train decided to change to another car... the mi5 was truly great at my local track which is low to med grip carpet, ran mid motor and it performed really well, moved to the evo and it was never on the pace, I could do the lap times... but really at a push car felt compromised every way we tried it. I know all settings are a compromise i.e gain one thing loose another but I was slipping down the order and becoming a regular in the b final. Decided to change car to see if it was me or the car or both and.... well for our track new car with kit setup proved to be the key.
Thanks for all the advise.
nmsraider is offline   Reply With Quote
Old 11-18-2014, 09:40 AM   #2452
Yep double joint front drive shafts, alloy rear drive shaft, looks like a 2.5mm top deck, Screw kit, pro servo plate, alloy servo posts, alloy servo arm, cut suspension arms and think I see the wishbone braces
Even if can't see I also bet the shocks are different inside ( Pistons & seals )
Old 11-18-2014, 03:11 PM   #2453
cementsurfer86's Avatar
What's the benefit of the Pro servo plate? is it thicker? I notice it doesn't have the cutout....
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 11-18-2014, 06:00 PM   #2454
TryHard's Avatar
Looks, and it's a bit stiffer (not that it matters to much when the servo is bracing it).
Old 11-19-2014, 06:01 AM   #2455
Ray k's Avatar
Trader Rating: 46 (98%+)
EVO chassis forsale, if anyone is interested .
Schumacher Mi5 EVO Aluminum Chassis
Ray k is offline   Reply With Quote
Old 11-20-2014, 07:40 AM   #2456
Damon's Avatar
ok, but all the parts you listed are optionals that already exist...yes, I was wrong to say that it is a standard car, I meant that there aren't prototype parts except new double joint front drive shafts
Awesomatix A800
Awesomatix A800X
Old 11-21-2014, 01:35 AM   #2457
Not saying the are prototype parts and the front drive shaft are old mi5 think mi4 one
Only option or upgrade parts in the pipe lines I know of are the duel bell crank steering to save weight
Old 11-21-2014, 01:47 AM   #2458
Default Question for TryHard
Question for TryHard (or anyone else if they know):
On your blog (an older post) you mention that Anti-dive should help braking performance, which is very useful in modified racing.
Would you mind explaining how this works?
Also, i think you based these findings on the old Mi5, have you found these also work in the same way on the evo?
Gino S is offline   Reply With Quote
Old 11-27-2014, 02:15 PM   #2459
Ended up getting a MI5 Evo. It was my pick because of parts supply online. Schumacher has parts for all the mi models and thats very impressive. I bought the car itself in Norway from a shop who has the brand. Local shop is nice to have too. thicker stabilisers is the only option so far. Im running carpet. Any setup tips for carpet?
Old 12-01-2014, 12:04 PM   #2460
Thanks! good stuff!
