Like Tree21Likes
Old 09-09-2014, 04:16 AM   #2386
Send a message via ICQ to MattW
Yes they would have been cut arms.
MattW is offline   Reply With Quote
Old 09-10-2014, 03:29 PM   #2387
It's finally arrived! my MI5 Evo.... As I am doing the build as I type I had a question. Intentions are to run 17.5 blinky. Which spur gear would be better to install. The stock 85t spur gear or the optional 44t spur?
Thx
OlTimer is offline   Reply With Quote
Old 09-10-2014, 04:17 PM   #2388
Trader Rating: 25 (100%+)
You will need the blinky motor mount if you use a 44t spur.
I use a 64t 48p spur with a 35t pinion to get a fdr of 3.30 with flat head screws to bolt the motor in.
I don't like the blinky motor mount because it moves the motor to far back.
Gtr r34 m-spec is offline   Reply With Quote
Old 09-10-2014, 04:19 PM   #2389
Thanks Mattw
Old 09-11-2014, 06:14 AM   #2390
dvsstrike's Avatar
Thx
you don't want to run 64p? if you do 96 is pretty common to run in blinky 17.5.
it just depends on the motor to run to find the right balance.
Tim Linayao
Team Schumacher Usa Core-Rc Team Powers
dvsstrike is offline   Reply With Quote
Old 09-13-2014, 11:53 AM   #2391
hydrakermit's Avatar
Me personally i run the 44t spur and a 24 pinion for the oudoor track i run at, I found this a great, its a great balance between acceleration and top end. for 17.5 blinky and the motor up max, the motor comes off at about 75C, which is fine for the motor in running.
Thx
hydrakermit is offline   Reply With Quote
Old 09-23-2014, 11:46 AM   #2392
reg
Does anyone know if the plastic ends that fit on the evo suspension arms fit on the 5?
reg is offline   Reply With Quote
Old 09-23-2014, 02:51 PM   #2393
They don't.
Old 09-24-2014, 04:03 AM   #2394
JWick's Avatar
Did anyone has a good starting carpet setup for the Mi5Evo?
I would say it´s a mixed track. Not to open, but also not real tight and Medium-High Grip.
We drive with LRP X20 17.5T Motors, Blinky Mode, 4.5 Translation (96t-38t 64dp) and LRP CPX Carpet Tires, 1350g...
Here is a 360° Picture of the Track:
ww*w.mst-estenfeld.de/tl_files/documents/ueber_uns/strecke/pano_indoorstrecke/fahrerstand.html
Until now, I only run the Evo on tarmac on my home track and it feel very good and constant, but i had little problems with my rear end grip. I had perfekt steering but at mid corner and a little bit at corner exit the rear of the car was to loose.
On the Raceday when it was wet, it was completly different with the LRP Dunlop rain tires. The Rear was perfekt, but i missed a bit steering, also when i changed the shock positions at the front and the rear. It was better, but not so perfekt.
This was my setup:
ww*w.dropbox.com/s/nvwtd6yceqi0h06/MI5Evo_ESM_6Lauf.pdf?dl=0
I also tested rear motor position on dry and on wet conditons, but it was a little bit to slow in the tight double harpins.
Here is a picture of my home track:
ww*w.facebook.com/310450135658475/photos/a.386086338094854.82018.310450135658475/649665445070274/?type=1&relevant_count=1
And the Layout on the last raceday:
ww*w.facebook.com/310450135658475/photos/pb.310450135658475.-2207520000.1411555630./621175777919241/?type=3&theater
I also have a video, but only one where we go in the wrong direction:
ww*w.youtube.com/watch?v=-JSzYMEZdUo&feature=youtu.be
In additon i must say my home track is a vers spezial track, because the grip level is normaly very very low and its a very bumpy track. So if you run with a formel car with a 17.5T motor your the half time in the air...
And i must say sorry for my bad english. I hope you understand what i mean
(To use the links you have to remove the * between the www)
Schumacher Mi5evo - The Evolution is there
Team CS-Electronic/Schumacher Racing-Cars Germany
Mi5evo/LRP Flow Works/Sanwa RX-461/Savöx SC-1252MG/Boomerang 6000mAh 90C
JWick is offline   Reply With Quote
Old 10-01-2014, 12:18 PM   #2395
mutley001's Avatar
This was my setup:
Personally I run the kit carpet setup with a few changes:
Green springs front and rear
1.3 roll bars front and rear
Short camber links (2dink rear hub plates)
Wide front wheel hexes
2.5mm top deck
This gives lots of steering so be warned but it's very fast!
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 10-05-2014, 05:50 PM   #2396
Potoczak's Avatar
Trader Rating: 111 (100%+)
Looking for a good base line indoor carpet setup for the Evo??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-05-2014, 08:49 PM   #2397
how many Schumacher drivers will be attending the IIS in Vegas this year? I will be there. running in 17.5 sedan and spec gt!.
gdcopbdcop is offline   Reply With Quote
Old 10-05-2014, 08:51 PM   #2398
has anyone used the alloy chassis on carpet yet? Any reports?
Old 10-06-2014, 09:36 AM   #2399
JWick's Avatar
2.5mm top deck
Thank you very much.
I will test it at the LRP-Challenge (18./19. 10.2014). I will also test an active rear suspension there. I inform you about the results
Here is a picture of the active suspension:
And one about of my Mi5 Evo, which I repurpled
And the matching bodywork
Old 10-09-2014, 11:34 AM   #2400
Attachment 1237588
Attachment 1237592
Attachment 1237593
I like the mod on the rear no cutting can use normal part let us know how it goes
tcboy1983 is offline   Reply With Quote
