Like Tree21Likes
Old 07-03-2014, 04:07 AM   #2266
Send a message via ICQ to MattW
But why wouldnt you just get the older Mi5 parts to fit an Mi5??
As has been said, the only difference is the pin size - 1/8" on Mi5 and 2.5mm on Mi5 EVO.
MattW is offline   Reply With Quote
Old 07-03-2014, 11:49 AM   #2267
Because they want the grub screw the evo has but u can mod the the mi5 hubs the same way I did
if you have control your not pushing hard
all or nothing
tcboy1983 is offline   Reply With Quote
Old 07-03-2014, 02:38 PM   #2268
hydrakermit's Avatar
Correct I ask because it will save me the ball ache of filing the pins down, seen as thou I got dodgy wrists and joints.
Thanks for the reply's anyways much appreciated
hydrakermit is offline   Reply With Quote
Old 07-03-2014, 02:54 PM   #2269
TryHard's Avatar
You'll still want to file a flat spot on the Mi5 1/8" pin, just to make sure that the grub screw can hold it in place.
Old 07-03-2014, 03:00 PM   #2270
Instead of a file use a dremel on the pin just go slowly with it lol
all or nothing
Old 07-03-2014, 03:10 PM   #2271
Yup, been putting the grub screw in Mi4/Mi5 caster blocks for a number of years. Just dremel a flat (of sorts!) on the pins. I'm sure this is a whole lead easier than trying to use the EVO bits.
Old 07-03-2014, 03:31 PM   #2272
So apart from being able to us small pinion gears do I get any other advantages from dropping from a fdr 3.05 running a 39t pinion and 66t sper down to a 29t pinion and a 44t sper with the same fdr?
I don't think I will but would u get it reving easier like getting a lightened flywheel on a real car ?
all or nothing
Old 07-03-2014, 05:05 PM   #2273
malcnz's Avatar
In my experiance with cycling the bigger cogs(more teeth) do last a lot longer.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 07-04-2014, 04:22 AM   #2274
malcnz's Avatar
Just got the evo and need to change spurs and can a std xray/cso/type fit as have loads of these?
Thanks.
Old 07-04-2014, 04:56 AM   #2275
TryHard's Avatar
Thanks.
Only Schumacher or RW Spurs fit, as they are designed for the bearing to fit in it.
Old 07-04-2014, 11:14 AM   #2276
I have some 64DP Spur gears for sale if anybody is interested, I have 2 x 114t and 2x106t, brand new in packets, I don't use 64dp so they no use to me, will sell as bulk or separate. If anybody is interested pm me.
Or alternitivly look here for what I have for sale.
Prefer UK buyers as its easier and cheaper on postage.
Old 07-04-2014, 11:16 AM   #2277
Don't have a dremel unfortunately
Old 07-04-2014, 11:31 AM   #2278
If u can get one great for model cars lol
all or nothing
Old 07-05-2014, 01:47 PM   #2279
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Default looking for mi5 chassis
If anyone has a chassis they can part with, shoot me a pm. Some scrapes are Ok, just no chips or cracks. Thanks.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 07-06-2014, 10:39 AM   #2280
What size 2mm or 2.5mm?
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
skater-deez1
