Like Tree21Likes
Old 06-25-2014, 04:09 AM   #2221
niznai's Avatar
Originally Posted by BardSmith View Post
Very cool. Thanks blokes.
I don't think anyone cares about smaller spurs and weight being 2mm (or whatever) further back. The blinky motor mount is primarily designed to allow for gearing impossible to achieve in the normal position. This would be the main reason. Keep in mind in classes like 21.5 blinky people run unbelievably small ratios such as 3 or thereabouts. In most cars these are not possible without some creative liberties (microscopic spurs/intergalactic pinions that didn't even exist before 21.5 and blinky came about).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-25-2014, 04:31 AM   #2222
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
The Mi5 and Mi5evo can easily achieve blinky ratios with standard motor mount. RW spurs available down to 64t or lower meaning ratios into the 2.x:1 range are achievable. All you might need to do is switch standard cap head motor screw to button head to clear pinion.
The blinky mount is a tuning option and is not required to run the standard car in at least up to 21.5
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 06-25-2014, 02:53 PM   #2223
heavy's Avatar
Trader Rating: 20 (100%+)
I run 21.5 blinky with the Mi5EVO and run a normal Schumacher 64t spur in 48dp with a 37t or 38t pinion depending on the track using button head screws to hold the motor. I have the blinky motor mount and will be trying it as it will allow the normal motor screws to be used with a washer and with good clearance from the pinion - will be using 44t spur and 25 or 26 pinion.
One big advantage of the EVO, over the original Mi5, for the blinky classes is that there are now 1 degree and 1.5 degree toe in rear arms available, I'll be running 1 degree next time I hit the track .
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 06-26-2014, 03:52 AM   #2224
scott_g's Avatar
Here's the Blinky motor mount in place, fitted up with 44t spur, ready to run with 21.5 motor.
Looks amazing!
Old 06-26-2014, 05:34 AM   #2225
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
The Evo being out a week now...Well it is better than Mi5?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-26-2014, 06:14 AM   #2226
BardSmith's Avatar
Trader Rating: 61 (98%+)
Looks amazing!
Which brand spur is that? Which brand spurs can be used? (other than schui)
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 06-26-2014, 06:59 AM   #2227
its unbelievable how much faster it is. spools up quickly, has tons more corner speed, and is easier to drive fast!. I'm looking to get another one!
gdcopbdcop is offline   Reply With Quote
Old 06-26-2014, 07:15 AM   #2228
shoman24v's Avatar
Trader Rating: 14 (100%+)
How would you guys rate the build quality of this car? I'm thinking of getting the EVO. I've never owned a Schumacher so I'm curious.
Also, where is the car made?
| HPI Blitz ESE | Reedy Mach 2 9.5 |Schumacher Cougar SV2 | (2) Team Associated RC10T | Shelfer/Runner | (2) Team Associated RC10T2 Shelfer/Runner | Team Losi XX & XX-T & XX-T CR Graphite Plus Shelfers | Team Losi XXX-4 Shelfer |
shoman24v is offline   Reply With Quote
Old 06-26-2014, 07:20 AM   #2229
The Mi5 I built was the most enjoyable R/C build ever, great instructions, very high quality parts - Evo looks even better.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is offline   Reply With Quote
Old 06-26-2014, 08:24 AM   #2230
chiefj48's Avatar
+1
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, Serpent USA, Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 06-26-2014, 08:43 AM   #2231
mutley001's Avatar
Made in th UK!
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-26-2014, 12:16 PM   #2232
shoman24v's Avatar
Originally Posted by mutley001 View Post
Made in th UK!
Thank you. I wanted to be sure it wasn't made in China or something.
Old 06-26-2014, 12:49 PM   #2233
BardSmith's Avatar
Looks amazing!
So what kinda pinion sizes have you experimented with for 17.5?
"Bard"
On-Road Only!
Old 06-26-2014, 02:43 PM   #2234
scott_g's Avatar
We don't run 17.5 in Australia so haven't tested. Spec classes are 13.5 and 21.5.
This car set for 21.5 with Schumacher 44t spur and I think 25t pinion (using blinky motor mount). I think that may be the only super small size spur available at the moment.
Spurs for evo are same as previous cars - so Schumacher or RW brand.
Old 06-26-2014, 02:48 PM   #2235
heavy's Avatar
Will take down to a 19t pinion (4.17FDR) so should cater for 17.5 blinky without any trouble. We only run 21.5 and 13.5 blinky classes here and they are no trouble so 17.5 should slot somewhere in the middle, probably a 22t or something.
