Old 06-15-2014, 09:35 PM   #2176
TryHard's Avatar
Originally Posted by jeff jenkins View Post
that is exactly what i did but it is still 1.2 mb
Try printing it as a jpeg? I know you can do this with bullzip, and then reduce the file size
Old 06-15-2014, 09:44 PM   #2177
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Is there anything extra needed to build it for carpet with the included hoffers setup?
Blitzrockey is offline   Reply With Quote
Old 06-15-2014, 10:03 PM   #2178
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
here is the set-up. thanks Phil!
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 06-16-2014, 10:48 AM   #2179
Just sat building my evo, I have a problem. looking from the back of the car the A arms on the left both front and back are binding on the crash post's. Is it just a case of getting the file out or have I done some thing wrong??.
big paul is offline   Reply With Quote
Old 06-16-2014, 01:06 PM   #2180
Did you assemble the inserts properly in the arms with the 1 dink and 2 dink pivots in there correct spots? Also on the mi5 if you over tighten the pivots the arm would bind on the bulkheads so loosen the pivots and redo them but use the wrench more than the hex driver when tightening them.
Serpent project 4x
Old 06-16-2014, 03:12 PM   #2181
Also check that the crash tubes have their flat sides against the wishbones
Schumacher Mi5evo-HW V3.1 - HW V10 13.5 dry car
Schumacher Mi5evo-HW Extreme stock-HW 13.5 wet car
Schumacher SSGT - HW V3.1 stock spec - HW V10 13.5
Racing-cars.com
MWarren is offline   Reply With Quote
Old 06-17-2014, 05:11 AM   #2182
`Yep done both of the suggestions. Got a email of to schui, they say file a bit of carbon fibre of the a-arm and it should be fine
And thanks for the replies
Paul.
and the pip thing is in the right order as per the manual ( after getting it wrong two or three times LOL.
Old 06-17-2014, 05:22 AM   #2183
TryHard's Avatar
Paul.
Thats the same thing we had to do on the 5 as well, as the arms could rub on the bulkheads. Just needs a little chamfer on the top side, and should be golden (it's most likely the corner of the carbon catching).
HiH
Ed
Old 06-17-2014, 06:38 AM   #2184
HiH
Ed
Right people time to eat humble pie But if it helps others hay ho. After the reply's I got. Had yet another look at the manual regarding the pip thing. What I had done is put 4 x 2 pip in the rear and 4 x 1 pip in the fount. Less speed more haste. Or fully read the manual. But in my defence this is the first car I have built that is not the same left to right.
Old 06-17-2014, 10:26 AM   #2185
Trader Rating: 22 (100%+)
Default Mi5 Stuff - Body / DCJs
Guys,
I bought an Mi5 a while back and had this body painted for it ($75). I mounted it on the car, then decided to sell the car before I ran it. Its brand new LTC-R body. I also have a brand new in package set of Schumacher brand DCJs ($45) for this car I dont need anymore either... or both for $110. I wouldn't normally post this stuff on the Mi5 thread, but these items are specific to this car and thought one of you might need or want it.
call or text me if you have interest 713.397.5545 -- Justin
Justin Cornett
RC America / XRAY / HUDY / KoPropo / Team EA Motorsports / AVID RC / RSD / ReflexRacing.net
gocoogs is offline   Reply With Quote
Old 06-17-2014, 03:00 PM   #2186
poochy's Avatar
besides being sure you followed the manual's instruction correctly on how to use the wrench to tighten the ball up--it can also be caused by too many crashes causing the ball to bind to the plastic it sits in--a drop of oil on the ball can cure this type of bind.
poochy is offline   Reply With Quote
Old 06-18-2014, 01:32 AM   #2187
Damon's Avatar
first comments about Mi5 evo from Martin Hofer:
http://hofaaa.wordpress.com/
and his setup used in Luxembourg:
https://hofaaa.files.wordpress.com/2..._lux_hofer.pdf
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 06-18-2014, 02:15 AM   #2188
Trader Rating: 23 (100%+)
Thumbs up
Did anyone's kit come with a servo saver?
Mine did - thanks schumacher!
Gtr r34 m-spec is offline   Reply With Quote
Old 06-18-2014, 05:07 AM   #2189
hydrakermit's Avatar
hydrakermit is offline   Reply With Quote
Old 06-18-2014, 04:49 PM   #2190
heretic's Avatar
Quick question for those of you building the mi5evo, how much does it weigh empty, out of the box ? By empty I mean: complete without wheels, electronics, or body.
Thanks !
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
SEO by vBSEO 3.5.0
